plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 13th, 2018, 03:37 AM   #1
Big_Robo
Supporting Member
United Kingdom
Big_Robo is offline
RS232 to USB with Tia Portal Modules.
Hi everyone.
I have been doing some reading and getting mixed results.
Here is my question. I have a RS232 module on my PLC. I want to connect that to a program running on a PC threw a USB adapter. Signals will be send and receive is it possible or am I wasting my time.
Old June 13th, 2018, 03:43 AM   #2
Manglemender
United Kingdom
Manglemender is offline
I did some RS232 interface work in TIA last year and it seems to work OK once I turned off the flow control. The PC end will need a serial to usb adaptor and as far as the PLC is concerned it just speaks RS232.
What do you actually need to achieve?
Nick
Old June 13th, 2018, 03:47 AM   #3
Big_Robo
Supporting Member
United Kingdom
Big_Robo is offline
Hi Nick thanks for the reply.
Yeah pc has a usb to series adapter. The PC has a program that send job codes and scale weight to the PLC. I have migrated an old S7 classic program so all nessary blocks are there just it doesn't seem to want to play ball.
Old June 13th, 2018, 04:58 AM   #4
Manglemender
United Kingdom
RS232 only describes the hardware. You will need to know what data is transferred and by what protocol. i.e. what message is sent, what should be done with it and what response is expected. I used a terminal emulator program that allowed forwarding one port to another on my laptop to help get things setup but I can't remember what program that was.
Nick
I think the program I used was Termite: https://www.compuphase.com/software_termite.htm
Old June 13th, 2018, 08:52 AM   #5
Big_Robo
Supporting Member
United Kingdom
Big_Robo is offline
Hi Nick. Sorry about the vague answer. I am using Freeport to send and receive ASCii strings. These strings are read in the PLC and does the required function e.g. ZERO (that would set scales to zero)
I will have a look at that software later. Thankyou
Old June 13th, 2018, 11:21 AM   #6
Manglemender
United Kingdom
I'm not familiar with Freeport but if all it does is send out ASCII strings then it should be doable.
There will be a set of function blocks provided by Siemens that go with your chosen hardware that handle port initialisation, send data, recieve data etc. There is likely to be a demo program on the Siemens website for your chosen hardware.
To make my system work I programmed a state sequence that first handled initialisation and then cycled through a sequence. yours might be something like:
Initialise port
Wait for new data
Read data
Decode instruction
clear buffer
Send response
Go to wait for new data
I than wrote two routines in SCL to handle the ASCII message creation and decode.
Nick
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
TIA PORTAL can't be linked to S7-314C- 2DP, via MPI mourad69 LIVE PLC Questions And Answers 0 September 17th, 2016 04:34 PM
TIA PORTAL can't be linked to S7-314C- 2DP, via MPI mourad69 LIVE PLC Questions And Answers 0 September 15th, 2016 10:54 AM
Step7 Classic or TIA Portal v13? Manglemender LIVE PLC Questions And Answers 13 July 31st, 2015 09:56 AM
TIA Portal hardware catalog in relation to F-DI / F-DO modules kobelu_090 LIVE PLC Questions And Answers 8 July 27th, 2015 11:38 AM
Will USB to RS232 Converter work?? ECSI LIVE PLC Questions And Answers 26 March 17th, 2004 02:22 PM
