Why I like ladder logic for boolean expressions
ganutenator
May 2002
kansas
1,440
Example:
Take this boolean algebraic expression:
note: I'm using a single quote to denote negation as I can't place a bar over the letter.
(CA + B' + C + D') * C
When you reduce this expression:
1) CA + CB' + C*C + CD' // multiply C by what is in parens
2) CA + CB' + C + CD' // we replace (C * C) with C because: C * C = C because: C AND C = C
3) CA + CB' + C * (1 + D') // we factor out C from (C + CD').
4) CA + CB' + C * 1 // (1 + D') = 1 because: (1 OR NOT D) = 1
5) CA + CB' + C // because: C * 1 = C or C AND 1 = C
6) CA + C * (B' + 1) // we know that (B' + 1) = 1 because NOT B OR 1 = 1
7) CA + C * 1
8) CA + C // (C * 1) = C because C AND 1 = C
9) C * (A + 1) // (A + 1) also known as A OR 1 = 1
10) C * 1 // C AND 1 = C
= C
Not immediately apparent that (A + B' + C + D') * C = C
Now in ladder as (CA + CB' + CC + CD'):
Yes, it is easy to see that OR'ing w/ C will make the output true if C is true;
Not as apparent if C is False.
It is not a perfect example, I just found it interesting.
It is to me. It is as simple as factoring out C. Also 20 years ago Terry Wood would show you how to use Karnaugh maps to simplify boolean equations.
https://en.wikipedia.org/wiki/Karnaugh_map
There are also some basic rules like de Morgan's theorem.
https://en.wikipedia.org/wiki/De_Morgan's_laws
The good think about ladder is that you can see what contacts are active. In my programming IDEs I can set up a watch window or just hold my cursor over the variable I want to check.
Well, if I remember correctly, you are quite the math genius. You in my opinion are not the norm.
I am not a math genius. I am good but not that good. I am at the point of "the more you know, the more you know you don't know".
"Always be skeptical of those who claim to be the best"
-Dunning Kruger
or what would have been said if there was ever a quote :D
Karnough maps are for analyzing and possibly reducing logic.
Ladder (and other languages) is to implement the logic, reduced or not.
I agree that Ladder is the best language for logic. Sometimes and with a little practice you can cut down unnecessary logic just by looking at the Ladder rung. But .. sometimes I leave unnecessary logic in, because commenting more is better than cutting down to the minimum. When you remove unnecessary code, you actually hide the considerations that were the reason behind the removal of the unnecessary code.
Ease of throubleshooting and maintaining trumps perfect optimization.
By the way, Siemens have added a new language to their TIA programming platform called "cause-effect matrix" aka CEM. Does sound similar to karnough maps. But I dont think the intention is to optimize the logic, only to make it very simple to program.
Someone asked on Siemens own forum "do you find CEM language useful? Will you use it?". No-one anwered.
https://support.industry.siemens.co...17-cause-effect-matrix-will-you-use-it/277410
So hey guys, new here. Long time listener first time poster. Have a question for you. I'm looking to get into some rudimentary programming...
5,214
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
98
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
193
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
419
Working on project will update after it is completed.
355
