Communicate with a Powerflex 70 AC Drive through Ethernet ip
Thank You
Ken,
The video was very useful. We have the process ready to go we are just waiting for instructor approval before we flick the switch.
I’m sure we will be posting more question as we try to finish our tech thesis project.
Thanks again,
Rick
Thanks!
This video is just what I needed to get some programming done without any drives to test on. This will save me plenty of time on a startup next week!
Mike
Spring can't come early enough, can it ?
I happened to be teaching seminars on this very topic this week and tried to capture the basics in a narrated slideshow.
It's pretty blurry because of the video compression, but it might show you the basics:
RSLogix 5000 v16 Premier Drive Integration on YouTube
I followed that guide but still the drive won't work XD
I can monitor the tags and see the inputs on the drive etc but when setting the start bit nothing happends.
The drive status is:
Enabled
Command Direction (Forward)
Rotating Direction (forward)
The drive works when doing the autotuning in the wizard.
Anyone got any ideas for me?
Are you sending the drive a speed reference?
If Speed reference = CommandedFreq my answer is yes :) in the video all he did was to set that tag and set the Drivelogic_rslt_start bit and then it worked.i have been struggeling with this for a few hours so i'm getting pretty tired and feeling stupid. and it's probably someting stupid also! :)
Is my wiring wrong? when i started this i didn't use any inputs at all and when i found this thread and that youtube video i saw that he used input 1 and 2 for stop/start i just wired them quickly so that they always have inputs.
To preface, these are the parts the guy had setup to use so its what I have to work with--ml1400 to switch to powerflex 525. Using msgs to...
1,929
Good Afternoon , We still have a number of Powerflex 70 drives throughout the plant. Many are being controlled by DeviceNet that I plan on...
6,646
hi everyone i need help regarding for the communication of Powerflex 7000 vfd to s7300 plc, there is no gsd file of powerflex 7000 in rockwell...
1,143
An existing project, that was working, is not communicating to the drive using RSLogix5000 PLC software V20. It will communicate using Connected...
1,439
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
557
