Had a weird issue with a fairly new installation of a Kinetix 5700 servo drive. We were getting an overcurrent fault on the system. Normal % current pull is around 100%, however we were getting around 340% current. Checked all mechanical, inspecting for any binds or tight spots, lubricated all sliding parts and joints. Was still getting the same issue of high current. Eventually tried power-cycling the equipment and the issue cleared up.
Just found that kind of odd that a servo repeated overcurrent faults would occur and then get cleared up by power cycling the equipment. Hope this helps if getting the same issue.
