Ez Touch Panel
jnra
Jun 2004
mexico
hello all.
I;m having problems with my Ez Touch panel its ez-s6m-r model.
it's was working very well, but the machine had a short circuit and, when I put it back to work again, the Ez did not work
just appears '' there is not power up screen''
then I thought well I'l fix this, but when I tried to connect to my EzTouch.
I choose the option '' Read from panel & edit off line''
but son after I write appear other dialog box that it says
Ez Soft Can't Read plc attributes from panel..
and that's all.
I was treating to fix it but I was not able to
could somebody help me with this
Have you tried to cycle power to the EZ touch, had one that locked up on me stuck on one screen, none of the toch cells were working had to remove power and restart, Also at commissioning on the same one the screens went out and had to re-download the screens.
Have you look at the indicator light on the back?????
Just a thought.
I've had EZTouch units that appeared dead be revived by removing the battery for a while and the redownloading to it. I realize that you were trying to get the application out of it so I hope that doesn't mean you don't have a current copy. What I am suggesting WILL REMOVE ANYTHING THAT IS IN IT. But I suspect you have nothing in it as it is. Good luck.
Edit: Also make sure that the serial port on the EZTouch is not set to printer.
Sounds like the "machine had a short circuit" caused the EZ-Touch to loose the project that was in the panel. At this point there is not a lot you can do, but to reload the original project offline then transmit it to the panel. You do have a copy of the original project right?
You're supposed to keep copies of the originals?? Go on!
How else are you going to reconstruct the file from scratch?
Ez Touch
thanks all people , that sents theirs messages
alredy the machine is working very well
I just made the screens again and I put them into the panel
& surprise its works
well. I'l take care, and i'm going to keep copies from my screens
thanks again
We broke the glass on the new PanelView Plus 7 .... 2 months after the install. Our vendor stated that we cannot buy the repair parts...(Touch...
200
Does anyone have any good recommendations on an industrial touch screen panel? I want to be able to panel mount the screen and have it connected...
2,750
We had a sharpening machine. It used Siemens S7-200. The touch panel Simatic 6AV6642-0DC01-1AX0 can't be used but still got display. How to...
3,556
Any suggestions for suppliers in Europe or even Sweden? Or brands and I can look for suppliers. Haven't bought in a while and now my mind's...
4,318
Hello Dears We have a plastic injection machine iml The problem now is that the touch panel has been off for a long time And now that we want to...
2,807
