How do i use the S7-300 plc with encoder, motor and drive to control motor position
Shadley
Sep 2009
Cape Town
Hi Guys
Im currently doing a project where i am having move a motor to any given position fwd and rev.I was given a s7-300 plc with anologue in and output cards, a telemaq drive and an encoder.
I never really worked with analogues and dont know where to start.How would my hard wiring look like between the components and how would my software program look like for moving my motor to any position i want to. Would i also be able to change my speed and how would i be working from a reference point.
Please is there any examples of the wiring and program of the application i can get, would really appreciate it alot
Shadley :confused:
For analogue you can start with checking FC105 and FC106 Scale and Unscale blocks in SIMATIC MANAGER.
For the encoder if you dont have a compact CPU you will need a FM module for high speed counter...Check this out.
With wiring you should check your motor plate information and encoder wiring diagram. Those information would lead you
While I'm not familiar with the S7 details, I would think that this person needs a single axis control module for his PLC. He's got to keep track of position somehow.
Or not?
Or not?
Nah with a counter module you count the pulses from the encoder and
know where you are on the axis.
Even more precise is using an absolute encoder.
I never really worked with analogues and don't know where to start.
This isn't good.
Usually the manufacturers have data on-line. I would look up the data for the telemaq drive first.
Hopefully the drive will have some smarts to it so the drive can be given a position reference from the PLC and the drive will send the motor there. Otherwise you have a long battle ahead.
Hi I want to read degree from absolute encoder 1024 binary by plc s7300. Please Describes the functionality of the absolute encoder 1024 binary...
4,336
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
190
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
661
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
972
Hello, I have a bit of a situation, and I think I know the answer but this font of knowledge may prove something. I want to do the unthinkable...
2,116
