FM350-1 Interrupt Request
Prince
Jun 2002
284
I am using FM350-1 with S7 315-2DP. I use the counter module to count the encoder pulses and cut a crossing plate on the desired position. I do not find the result precise enough. Can I have a faster response if I use an interrupt in FM350-1? If so, Can you please give me an advice on the method?
In general do you have a suggesstion for me?
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M...
1,907
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,137
For a revamp we will have a configuration with S7 1500 and FM350 in ET200M on profinet. Will the FM350 work? Because I see in Siemens Tia...
2,703
Dear All, Hw config. are 317-dp cpu with FM350-2 counter modle. Connect HTL encoder A to FM module nr 5 and B to Number 8. (mean channel 1)...
1,847
We are currently encountering configuration problem with FM350-2 used for counting and totalizing functions. When we configure the FM350-2 and...
3,162
