ganutenator
I am quoting the following passage out of a workbook from an Instrument Class taken from NTT. I would like to fully understand this method, but the passage leaves me with a few questions . Can anyone shed more light on this subject?
It says to adjust the gain (or proportional band) from a very low value until a quarter wave damped oscillation is observed when a Setpoint bump is applied.
- How do I do this? How do I know when I have a quarter wave damped oscillation? What values do I put on my trend? Do I scale the values 0-100%? What sort of period do I need on my trend to observe quarter wave damped oscillation?
Only the period, P, is measured with a stopwatch.
- How do I do this?
The gain is then lowered to a very small value? How low? 0 gain or 500% Pb?
Symbols:
Ti(integral ?) ?
Pu (gain ?) ?
Td (derrivative ?) ?
I am using a modicon PID2 controller.
my proportional band is entered in 5-500%
my reset is entered in 0.00 - 99.99 repeats per minute.
Tuning Method - Damped Oscillation
This Method is very similar to the Zieglar/Nichols method. It is used when sustained oscillations are not allowed and the Ultimate method cannot be used.
The integral and derivative are removed by setting the integral time to infinity and the derivative time to zero. The gain (or Proportional Band) is adjusted from a very low value until a quarter wave damped oscillation is observed when a Setpoint bump is applied.
Only the period, P, is measured with a stopwatch. The gain is then lowered to a very small value and then Integral and Derivative (if required) are set according to the below equations:
Ti = Pu /1.5 and Td = Pu /6.0
The gain is then increased until quarter wave damping is again observed in response to a setpoint bump.
- How do I do this?
Symbols:
Ti(integral ?) ?
Pu (gain ?) ?
