Setting Internal Tag "Start Values" in WinCC
Rusty_K
Mar 2004
Norway
73
Hello,
I'd like to know if anyone knows how to set internal tags in WinCC such that they are not reset after WinCC is shut down and restarted. Basically, I would be looking to modify the "Start Value" of an internal tag through runtime. Any help would be greatly appreciated.
Cheers
R.K.
Rusty,
I don't think it's possible, can't you use a externel tag ?? or tel me your problem
and I look into it
Greetings Marcel
Hello,
I am using WinCC V5.1 HF2 with the WebNavigator and would like the user to be able to modify values of certain internal tags. These modifications should remain the same whether or not WinCC is restarted...in essence am I able to modify an internal tags "Start Value" during runtime? Are these "Start Values" of the internal tags stored in the WinCC database and if so, am I able to access and modify them during runtime via C script or by some other method.
Cheers
R.K.
Well, think of internal tags as global variables in a programming language.For example, if you write a VB program and declare a var:
Dim x
and then run this little program and after a while x becomes 5 (x=5), this remains only for the time the program runs. When it stops, variable x does not exist. In your case, the tag is reset when you shutdown, so you can keep the value of this tag in a text file(this can be done by an C action when the user presses a custom "shutdown" button and NOT the stop button in the CC!!), and load it everytime the Runtime starts.Hope it helps!
Nick
I had also this problem, I found only some work arounds..
1st put these tags in a Usrer Archive or
2nd write them into a normal Ascii-File
both will work, but the 1st one is easyer, but more expansive if you don`t want to use these Archives as well...
happy programming
Raabun
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
27
630
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
81
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
76
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
282
