Factory Talk View Site Edition 9.0 Auto logout/login after idle time
1. Create user group. Example "Maintenance"
2. User1, User2, User3 all add under "Maintenance" user goup
3. On runtime security, goto "Maintenance" user group & use this "pause 60;Login DEFAULT DEFAULT" at Login Macro
4. each time User1, User2, User3 login in FTView Client, there will be timer 60sec then will automatically login to default user.
5. Change the name & time base on your application.
đź“šo_O
hmm, it logs out the current user which is working on the panel?
For me that would be a no go, because i want only be logged out if nobody is working on the panel.
that would be different scenario. i believe you need to use ActiveX-Idle Detect Control. Hopefully it works
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
316
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
279
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
566
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
354
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
663
