continuously replacing shaft seals on Servomotors
Kataeb
Jan 2007
www.livelovelebanon.com
636
Are they serious ?
Replacing, every few months, a shaft seal on a Servomotor !
Shaft Seal Kits
https://literature.rockwellautomation.com/idc/groups/literature/documents/in/2090-in012_-en-p.pdf
A shaft seal is recommended if the motor shaft and end bell are exposed to significant amounts of containments, such as oil, fluids, or fine dust. Use a shaft seal in these environments to prolong the life of the motor.
Shaft seals are subject to wear and require periodic inspection and replacement. Replacement is recommended every 3 months, not to exceed 12 months, depending on use.
That would be a good reason not to use that motor. Motor seals should last years.
I did notice that they say to inspect every 3 months not to exceed 1 year.
Inspection is always good catch problems when they are still small and easily fixed
I'm working on a system with three Panelview 7's connected in a DLR. The system started having miscellaneous DLR faults and they were supposedly...
486
Hi everyone. Been banging my head against a wall trying to figure out tracking on a servo driven conveyor. I already have a tracking array setup...
3,402
I have established communication with a sensor via ASCII protocol using the Micro-850 PLC. I have a program which writes to the sensor using an...
1,888
Hi all, I want that a vb scripts run continuosly in wincc. My code get a print screen when a specific bit as equal 1 and other code set a time...
3,175
Here's an interesting one. I have an S7-300 and am using TIA Portal V13. I have a pressure/flow (p/Q) control valve for oil pressure for...
3,256
