isajadh Member I Join Date Apr 2006 Location Dubai Posts 11 Nov 16, 2018 #1 IAM using an fx3u unit. I have 6 (OR) rungs in a program which will turn on an auxiliary relay . How can I simply the steps
Mad_Poet Member M Join Date Feb 2017 Location Virginia Posts 375 Nov 16, 2018 #2 Put the six rungs into one rung - with all the contacts in parallel? -----|---[ ]----|----O-- |--[ ]-----| |--[ ]-----| |--[ ]-----| |--[ ]-----| |--[ ]-----| |--[ ]-----| Poet. (That didn't work too good . . .) Last edited: Nov 16, 2018
isajadh Member OP I Join Date Apr 2006 Location Dubai Posts 11 Nov 16, 2018 #3 Thanks for your reply. Yes your drawing is right But is there any way to combine them all like zrst resets up to 8 inputs at a time . Is there any ways to make inputs like that?
Mad_Poet Member M Join Date Feb 2017 Location Virginia Posts 375 Nov 16, 2018 #4 Hmmmm. . . [ ]---------------O--| In-1 | | [ ]-------| In-2 | [ ]-------| In-3 | etc. etc. (Apparently it does not like 'white' spaces . . .) Last edited: Nov 16, 2018
sczot Member S Join Date Nov 2017 Location cz Posts 80 Nov 16, 2018 #5 use Kx anotation K2M100 will take 8 bits (from M100 to M107) than https://imgur.com/a/N4NRqQb
lfe Lifetime Supporting Member L Join Date Jun 2007 Location Barcelona Posts 878 Nov 16, 2018 #6 with ladder logic, if the 8 M contacts are consecutive beginning with M100 |--[ <> K2M100 K0]---------O---| Last edited: Nov 16, 2018
