Factory Talk View Studio ME exporting tags Problem
robbo
Nov 2005
Australia
85
Hi fella's,
I had a search for an answer to this prior to posting.
I am using Factory Talk View Studio, machine edition V5.00.00 and when I Tools>Tag import and export wizard I come to a selection box which reads :Export RSview database to CSV files.
I am not using RSview tho? The pop up box only has .RSV files that it can select. I am pretty sure I need the .MED files, but cant select it.
Anyone got a workaround for this one? I dont have the same issue in Site edition, and the CSV exporting/importing works great.
Tah :)
Ah forget about it.
Not sure why this is so, but opening the progam another way does the trick.
start>programs>rockwell software>factory talk view>tools>tag import and export wizard
I've seen that before; I think it only happens if you have RSView32 and FTView Studio on the same PC.
I got in the habit of launching the tool manually.
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
261
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
223
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
503
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
330
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
617
