Any display with Siemens S7 200??
Preeya
Nov 2003
112
Hi everyone,
I am using a S7 200 PLC for a dosing application. As such I only need two parameters entered to the PLC on a continuos basis. The parameters are dose delay time and dose duration time in ms.
At present I use a TP 070 touch panel where the operator enters this time. Does anyone know any cheaper display other than the touch panel TP 070 for Siemens S7 200 that I can use?? Is there any third party devices I can use that can communicate with S7 200?
Thanks!
Thanks for your reply! I will look at TD 200. Do you know if user entry of values is possible in that? As I said I only need 2 parameters to be entered and displayed.
Siemens OP3 is approx 400 USD.
There is a starter kit with an OP3 + Protool lite for approx 800 USD.
edit: TD200 is approx 250 USD. Dont know how much for the configuration software.
As S7-200 uses the relatively simple PPI protocol with no particular hardware required, there must be a lot of 3rd party HMI displays.
Try to google with "HMI PPI", "Touch screen PPI", "Touch panel S7-200" etc.
Preeya
You can enter variables with it, but you've only got up, down, left, right arrows so it can be a bit of a pain.
The TD200 assigns which address you use based on what 'message' is being displayed.
TD200 wizard in MicroWin is pretty good.
pp
Hey tarok.seal,
I guess you're just trying to be helpful but I can't see the point in posting responses to 2+ year old threads..you've done it a few times now..
....or am I just grumpy this morning?
Dear All, I have system which include S7-200 and TD 200 I am facing problem when TD200 alone connected with S7-200 CPU 224 then continuously...
2,723
Dear All, I have system which include S7-200 and TD 200 I am facing problem when TD200 alone connected with S7-200 CPU 224 then contineously...
3,484
Im using a TD200 with a S7-200 PLC. I have configured the alarms, and i have set it to default to operator/user screens not alarms at the...
3,810
Hi, Wondering if anyone can help... I've been asked to make minor mods to an S7200 and text display (TD200) but my client has lost all backups...
3,313
Hi I'm trying to display a value on the HMI. In monitor mode on the code, I can see that value, but on the HMI , after downloading, it is...
926
