Saia pcd2 m120
Superfunk
Jan 2004
I saw this real cheap Plc saia pcd m120
on an auction site. There is , however no software with it. So, i' am wondering wether it still would be a good deal?
I am a total beginner when it comes to plc
so if any one wants to share it's opinion on this issue, that would be really great.
Thanx
This PLC can be programmed with this software.
You can learn on any PLC but for a beginner, I would advise a more broad-based brand. This way you could exchange infos more easaly.
You should also be able to purchase a starter kit or even a second hand PLC of a known brand from e-Bay .
But,
First of all, get Phil's book .
Superfunk, since you are from Belgium I suggest you take a look at the Automation Direct products from www.plcdirect.nl
Easy to program, good support (from this site) and cheap
Good luck
SAIA PCD2.M120
Here are some links regarding this PLC:
Saia PCD support page: http://www.sbc-support.ch
PCD2.M120 manual: http://www.sbc-support.ch/pcd2/mxxx/m1x0/pcd2m120.htm
PLC programming cable: You can make it yourself. The diagram is in the manual.
Programming software: The lastest software, is PG5: http://www.sbc-support.ch/pcd8/pxxx/pcd8p5.htm
On the support-page there is a full version of PG5 v1.2.130, running for 90 days.
Unofficial PCD forum: http://www.pcd-forum.de/
SAIA in Belgium:
Saia-Burgess Benelux
Mechelsesteenweg 277
B-1800 Vilvoorde
Belgium
Phone: +32 (0)2 456 06 20
Fax: +32 (0)2 460 50 44
Regarding which PLC to start playing with, I agree that it would be better to start with another brand, since starting with this one and switching to another would be a real disappointment... ;)
hi, i have a machine with SAIA model number PCD2.M5540. Recently i am facing issue regarding the run and stop mode. i tried setting the plc to...
1,816
Hello Friends I need to backup a SAIA PCD2 (pic attached). I have no experience with SAIA. Which software do i need? which cable? I have read...
1,913
Gents, I have a PLC and HMI from SAIA Please, see in the attached pics and tell me how to upload the programs to the PC (PLC and HMI) Tons...
2,272
helo sir /madam i have a old saia burgess pcd2 m110 plc.(1996) i down load the pg5 from the net and i am able to communicate .(i am able to upload...
3,335
Hi all. I have problem with RIO moduls. 1. Can I download somwhere list of fault code? 2. e006 on RIO is lost commucation on profibus? 3. is...
1,646
