Loop Performance Package
kumar123
Sep 2004
This is not a PLC specific topic, but I am sure I will get repsonses from this site as there are lot many control gurus visiing this site.
Do you think 'Loop Performance Pakages' add real value to your process. If you were to select a 'Loop Performance Pacake' what you would look into and why would you go for one.
Loop performance package I mean is the one which optimizes the control loops (Regulatory loops-PID) and has loop tuning, loop tuning, power spectrum and auto-correlation etc.
Kumar
kumar123 said:
Yes, if the only problem is finding the PID gains. Even a good tuning package cannot make a PID control a system that can't be controlled by a PID alone. A major problem is that too many people think all they need is a PID and a PID can correct for poor design.
I don't need one. I can fiqure it out my self. I would look a packages that try different models and provides a best one. I would make sure the tuning package also recommends good feed forward values.
Finally, I would choose a package that allows me to choose the response by placing the poles.
Kumar
[/B]
Optimize? Define optimized. Which evaluation method would you use?
There are many evaluation methods ISE, ITAE, IAE etc. You should be able to choose one that fits your application. See my PID threads.
Power spectrum? Auto-correlation? Why? I know, they are fancy names that people like to throw around.
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
143
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
263
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
266
Hello All Could we get some expertise on flow control ? -Using a PID loop in Productivity 2000 with an analog output, How can we convert...
19
1,564
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,067
