Modbus RS485 or Ethernet for 27 plc network
JimR
Oct 2004
24
I have a system in which I have to put together a network of 27 PLCs with an HMI. Each PLC will have an encoder connected to it and be controlling the position of a motor shaft. I'll probably be using the KOYO DL06 plcs. I'm trying to decide whether to go with Ethernet or Modbus RS485 for the protocol. I'm concerned that the polling time for 27 PLCs on the bus will be slow with Modbus RS485. I think ethernet would be easier when it comes to debugging and maintenance but I've never used it in a system like this so I'm unsure which way to go. For the HMI I would like to use Maple Systems but their panels don't support extended addressing via Ethernet Modbus TCP/IP. Other than this it looks like they have a lot of great features the EZTOUCH panels from Automation Direct don't have. Are there other HMIs that can control via Ethernet Modbus TCP/IP? If you have any thoughts please let me know. Thanks!
Jim
Adding to this question, has anyone used the EZpanel Enhanced HMIs from EZautomation? Looks the same as EZtouch with enhanced software. I'm particularly interested in being able to overlay buttons. Does this mean I can send out multiple messages with one touch without having to resort to a recipe object? Thinking about using EZpanels for the application below. Still looking for suggestions for implementing this application.
JimR said:
Jim
Hi all, How to convert RS485 modbus communication to Ethernet connection??????:nerves: In my upcoming project the customer needs “alarm and...
9,188
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
221
I am trying to figure out some communication specifics for a Modbus RTU network that I will be integrating with and could use some help to make...
2,079
I'm getting no response from a device I'm trying to communicate to with a Beckhoff IPC. I'm not sure why it's not working. Attached are pictures...
626
HI guys: I am attaching several diagram from several sources, it seems to be that there is no such a wiring standard for modbus RS485 RTU. In some...
24
4,519
