S5 Siemens to HMI
lambles
Aug 2003
South Australia
20
I have a Siemens S5 135U with 928B processor. It has 2 serial ports, 1 for programming (used frequently) and another for HMI (current use is for OEM HMI). Problem is I want to add another HMI package to the PLC as the existing OEM one that we have cannot be moified.
Can I 'split' the serial ? Is there a card that can be bought for more serial or Ethernet comms?
New HMI will be RSView via KEPServer
Any help appreciated....
Hello !
If I remember correctly you can buy the second card with two serial inputs, if you have the cpu with changeble second "comm-card"
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
98
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
299
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,444
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
160
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
579
