Using Parameters set to 1 or 0 for button visibility
I want to use a parameter in the visibility expression for button on my menu, what I'm doing isn't working.
I want to open a menu display and pass though a parameter file with it to determine which buttons on the menu display will be visible. So far I am passing through values like this:
#201=1
and then on the menu display I set the visibility animation expression for a button to {#201}. Intending for it to be visible when #201 = 1 and invisible when #201 = 0.
I know I'm passing the par file through to the display when it is being called but the way I have it set up still isn't working. Does anyone have a better way to do this?
I'm getting an errors "Failed to resolve item's ID '1' because it does not exist on any server" and "[FactoryTalk]: The Item is no longer available:#201."
Thanks in advance.
#201=1
Thanks in advance.
