Connect Siemens HMI 6AV2 124-0MC01-0AX0 with PC/Laptop
akhmadzaki
Nov 2020
Indonesia
I have a Siemens HMI 6AV2 124-0MC01-0AX0 in my machine. I want to clone the display on the HMI to PC/Laptop. My question is:
1. What software that I need for this task?
2. What kind of interface that I need between the HMI and PC/Laptop (for example ethernet cable, etc)?
3. Do I need to communicate with PLC connected with HMI or can I just connect with the HMI?
Thanks in advance for the answer.
If by "clone" you mean remote control the TP1200, then on the TP1200 you can enable the smartserver. This allows you to remotely control the TP1200 by a smartclient on either a PC or a smartphone.
You need the original TIA project for the TP1200 panel, and at least TIA WinCC Comfort.
Here is a vid on how to setup the smartserver:
https://www.youtube.com/watch?v=_fxSgJGYmvU
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,483
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,536
We have plc siemens m7 300 , and we want to connect it with HMI
3,754
Hi i am new one in simens hmi & drives. I am using CPU313-2DP . I have to connect simens HMI(MP277) & SIMENS DRIVES at same time. how should i...
3,357
Dear guys, I have a software that sends data to PLC using modbus. I want to connect my software with siemens plc, how can i do that?
19
4,609
