plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 2nd, 2004, 10:03 AM   #1
93lt1
United States
93lt1 is offline
93lt1's Avatar
UL 508A
I have a few questions regarding the UL508A specification.
I believe this spec. requires a seperation of power and control wiring/devices in a control panel. What is required to comply with the term "seperation"?
The system I am talking about is 208V 3ph. power and 120V control. It is a small panel: 2 motor starters, Micrologix 1000, disconnect etc.
__________________
SSC Automation
Old September 2nd, 2004, 12:28 PM   #2
icky812
United States
icky812 is offline
icky812's Avatar
For starters you are not allowed to run power wiring and control wiring in the same busway(Panduit) or bundled together.
I always had at least an inch of seperation where wires had to run parallel and never had a problem with my UL inspector.
In my dealings with UL using common sense was typically the right thing to do.
Your mileage may vary...
Old September 7th, 2004, 11:51 PM   #3
93lt1
United States
93lt1 is offline
93lt1's Avatar
Is there any other little know facts, oddball stuff, etc.?
__________________
SSC Automation
Old September 8th, 2004, 12:24 AM   #4
Bitmore
United States
Bitmore is offline
Bitmore's Avatar
The stipulation is that they must be physically separated. The spec also states that in a wireway there must be some physical device or construction practice that can accomplish this separation. In practice we usually use panduit like 2 2inch panduit (one is stripped of one side) and place them under a 4inch cover. Other physical means are acceptable, for one OEM we separate the Medium Voltage (high voltage doesn't start until greater than 600 volts?)with a grounding mesh of copper braid that is anchored by the panduit mounting screws every 4 inches. But as was started before "results may vary!" Crossing wires has never been an issue with any inspector I know, as long as, the insulation of both conductors is rated for the highest voltage present.
just a bitmore
__________________
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." Freeman Dyson
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
UL 508A Class ndzied1 LIVE PLC Questions And Answers 8 July 12th, 2004 09:13 AM
UL Listed panel shop RDay LIVE PLC Questions And Answers 5 January 11th, 2004 06:59 PM
"E-Terminals" opinions... Eric Nelson LIVE PLC Questions And Answers 41 January 6th, 2004 02:39 AM
230v Estop Steve Crotty LIVE PLC Questions And Answers 30 March 17th, 2003 07:46 AM
UL Ratings MCMOORE41 LIVE PLC Questions And Answers 7 January 29th, 2003 02:53 PM
