plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 16th, 2016, 10:47 PM   #1
coopdegrace
Australia
coopdegrace is offline
Pulse Input Wiring
Hi Guys,
I have a question regarding the wiring pulse output from a E&H flow meter.
Flow meter is a E&H 10P and input card is AB 1734-IB8
Question is how do I connect this up correctly so that I can read the pulse?
Do I wire the Pulse -ve (Terminal 25) to 0VDC and the Pulse +ve (Terminal 24) to my input?
Or Do I need do I need to supply 24VDC to the Pulse +ve (Terminal 24) and wire the Pulse -ve (Terminal 25) to my Input? If I do this will i need a current limiting resistor??
I have had some good help on this forum and just want to say its appreciated.
Cheers
Old May 16th, 2016, 11:00 PM   #2
Bullzi
United States
Bullzi is offline
This is a passive open collector output so you will need to provide the power for the pulse. You would do exactly what you what you said. 24VDC to #24 and #25 to your PLC input. Make sure you connect the COM of the input card to the same negative of the power supply you used for the pulse.
As for the Pull Up Resistor I would look at the manual for the meter to make sure. The E+H meters I have worked with in the past had an internal resistor so an external one was not needed. But check it out in the manual first.
One last thing to keep in mind is to make sure you set your K-Factor (pulses/volume) to a rate that the IB8 can handle. Also don't set your pulse width too small or the card may not count the pulse either. I have a spreadsheet that will compute your pulse width based on flow Fate and K-Factor. If you want it send me a PM and I will email it to you.
__________________
There is never enough money to do it right but there is always enough money to do it again.
Old May 16th, 2016, 11:26 PM   #3
coopdegrace
Australia
Thanks Bullzi, Just PM'd you.
Old May 17th, 2016, 12:10 AM   #4
Bullzi
United States
Bullzi is offline
I just looked at the specs for the 1734-IB8 and you will not need a Pull Up resistor. It has a max draw of 5mA which is well under the 250mA max draw of the output.
PM me your Email address and I will send you that Spreadsheet.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Instantaneous FLOW & totalizing from pulse input mondi_19 LIVE PLC Questions And Answers 6 August 27th, 2014 08:53 PM
Help with analog input module wiring!!! Joel201 LIVE PLC Questions And Answers 13 July 25th, 2014 03:25 AM
Floboss 107 Pulse Input elmatador LIVE PLC Questions And Answers 1 April 5th, 2011 08:40 PM
Analog input wiring question Von LIVE PLC Questions And Answers 8 July 18th, 2006 10:14 AM
AB Analog Input Module Wiring... Eric Nelson LIVE PLC Questions And Answers 3 May 6th, 2002 09:37 AM
