plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 26th, 2016, 04:08 PM   #1
Qulu Quliyev
Azerbaijan
Qulu Quliyev is offline
SoMachine Basic, Comparison problem
Hi everyone,
I am beginner in the plc programming, and I am learning it using SoMachine basic software. There is a comparison command, which I have problem to work
with that. I want to compare two bits, and write the valid expression in below form:
[%Q0.0=%M0]
However, software gives me error. Can anyone help me with that ?
Any help is highly appreciated.
Best Regards,
Old June 27th, 2016, 02:48 AM   #2
chud
South Africa
chud is offline
chud's Avatar
you dont use a compare function for bits. only for values like int or float.
If you are using ladder then just put the 2 bits in series either normally open or closed. Or if you are using function blocks just use an and block
Old June 27th, 2016, 02:58 AM   #3
Qulu Quliyev
Azerbaijan
Many Thanks, Sir..
Old June 27th, 2016, 03:41 AM   #4
shooter
Netherlands
shooter is offline
shooter's Avatar
%Q0.0 is an outputbit and %M0 is a Marker however it should read %M0.0 so you forgot something
and yes you may use =, however better is to use EQ.
@chud you will have to use the EQ block both in ladder and ST as AND gives only result when both are TRUE
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old June 27th, 2016, 10:56 AM   #5
Qulu Quliyev
Azerbaijan
Many thanks to you as well. However, EQ block does not exist in SoMachine basic software, unfortunately.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
M221 processor SoMachine basic canít figure out serial Dorrance LIVE PLC Questions And Answers 4 November 1st, 2015 12:30 PM
Basic Problem? cmarinello LIVE PLC Questions And Answers 4 October 28th, 2015 09:32 AM
TI-565 Weird comms and/or config problem RoTaTech LIVE PLC Questions And Answers 7 May 4th, 2009 05:59 PM
Ab Plc5 Rio Problem. fernandes LIVE PLC Questions And Answers 5 March 7th, 2004 01:25 PM
PLC5/40 Backplane Problem????? Andrew Evenson LIVE PLC Questions And Answers 18 August 24th, 2002 07:06 PM
