so how do you pronounce "WLag" and sound reasonably intelligent?
Ron Beaufort
Jul 2002
Charleston, SC
5,701
I finally have to work through an RSLogix5000 project that really makes use of the LPF (Low-Pass Filter) instruction in Function Block Diagrams ...
I've already developed all of the material that I need except for one thing ... I've Googled - and I've searched – and I still can't find out how to correctly pronounce the names of the WLag setting – or the WLead setting that's used in the HPF (High-Pass Filter) instruction ...
I'm 99.99% sure that the English "W" character is being used to represent the lower-case character for "omega" in Greek ...
so here are my best guesses so far:
(A) WLag should be pronounced Omega-Lag ... and
(B) WLead should be pronounced Omega-Lead ...
or on the other hand - maybe ...
(C) WLag should be pronounced Lag Frequency ... and
(D) WLead should be pronounced Lead Frequency ...
or maybe something else ???
I'm open to suggestions ...
and some "fun with filters" squiggly lines to help make the point ...
the RED trace is a sine-wave signal being fed to an analog output module ... this is wired directly into an analog input module ...
the YELLOW trace is what the analog input module is reporting ...
during the first couple of cycles, there is no "noise" signal being applied to the output ...
then when the "noise" is suddenly added onto the output signal, the "filtered" input signal represented by the GREEN trace shows the result ...
changing the value of the "WLag" setting (regardless of how you pronounce it) - demonstrates how the Low-Pass Filter can remove the higher frequency "noise" signal - and let the lower frequency sine wave pass on through ...
in the last section, too much filtering has been used - and the filter is now attenuating the sine-wave signal as well as the "noise" ...
and more fun with filters ... this one illustrates a "High-Pass Filter" demonstration ...
this one filters out the lower frequency sine-wave - and lets the higher frequency "noise" signal pass through ...
oops! ...
thanks, Keith - you were right ... it's getting too late for this type of fun - and I've made too many cuts and pastes ... I've fixed it now ...
thanks for the catch ...
Hi; I have Weintek HMI MT8051XE at a machine. I want to play a customized alarm sound. I uploaded the alarm sound in project and downloaded to...
1,626
Dear Memners, i have an issue regarding factory talk view alarm sound, i have set internal bell for sevarity =1, internal speeker are working fine...
2,135
wanting to setup an allen bradley 855 amber stacklight and siren to go off when an alarm pops up on my Panelview 1000 HMI. not sure if it can ran...
1,242
Hello All, We are using two "QUINT-PS/1AC/24DC/20 - 2866776" Power supplies for one of our project. The input power is single phase 240V and out...
3,774
Could someone suggest any instrumentation to internally view non conductive material? Example : Validate a centered wick in a candle internally...
1,475
