plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 5th, 2016, 04:52 PM   #1
Dave42
United States
Dave42 is offline
Question Issue Moving 1734 AENT From One PLC to Another
I had a 1734 AENT module that I wanted to move from a PLC that had very little downtime (runs the main process of my plant) to a PLC that I could take offline and test trial code on.
This 1734 AENT module only has one IB4 card running on it.
PLC 1 is a 1756 L63 Firmware revision 17
PLC 2 is a 1756 L61 Firmware revision 19
I started the transfer process by inhibiting the AENT module in PLC 1 and then adding it to PLC 2. This is where the problem started. PLC 2 can poll information from the AENT and know if it is owned and configured but gets a comm fault 16#2023 and will continually switch between an internal state of unconnected and not being owned to an internal state of Run Mode and being owned.
Now to try and resolve this I tried power cycling, restarting the AENT from Logix5000, Upgrading to a AENTR, and changing the IP address. But the problem still persists.
I am thinking there is some lingering connection to PLC 1 that is kicking PLC 2 off. Is there some way to clear this or is something else happening here?
Old September 5th, 2016, 06:11 PM   #2
ASF
Australia
ASF is offline
What is the error message shown along with the error code? I can't find any reference in the knowledge base or RSLogix help to error code 16#2023.
Old September 5th, 2016, 08:21 PM   #3
robertmee
United States
robertmee is offline
robertmee's Avatar
You'll need to re add the module as listen only...just inhibiting it doesn't release ownership if I had to guess.
Old September 7th, 2016, 12:52 PM   #4
Dave42
United States
Dave42 is offline
Quote:
(Code 16#2023) Connection Timed Out
Also searched knowledge base with no results
Old September 7th, 2016, 12:59 PM   #5
Dravik
United States
Dravik is offline
What version of firmware is the AENT at, and what version of firmware is your 1756-E whatever card at?
There are some known issues with firmware compatibility.
Old September 7th, 2016, 01:04 PM   #6
Dave42
United States
Dave42 is offline
1756 L61 v19.12
1734 AENTR v4.2
Old September 7th, 2016, 01:10 PM   #7
Dave42
United States
Dave42 is offline
Quote:
Tried This and now I get
(Code 16#0119) Connection Request Error. Module not owned
Old September 7th, 2016, 01:21 PM   #8
Dravik
United States
Dravik is offline
Quote:
Originally Posted by Dave42 View Post
1756 L61 v19.12
1734 AENTR v4.2
Right, sorry, was curious about the ethernet module FW in the Clgx base as well.
I can't find the release notes for 4.002 offhand, but you need a minimum FW revision on the ethernet card talking to the AENT as well in order for it to work right.
Old September 7th, 2016, 01:22 PM   #9
Dave42
United States
Dave42 is offline
Ah, It is a 1756 ENBT v4.3
Old September 7th, 2016, 01:26 PM   #10
Dave42
United States
Dave42 is offline
And it looks like ENBT 4.3 dislikes AENTRs in general...
Old September 7th, 2016, 01:26 PM   #11
Dravik
United States
Dravik is offline
I assume you mean 4.003 , In which case you need to rev that module to at least 4.006 for support.
"If you use the 1734-AENTR or 1738-AENTR adapter with a 1756-ENBT or
1768-ENBT module, use the following firmware revisions for these bridge
modules:
1756-ENBT firmware revision 4.006 or greater
1768-ENBT firmware revision 2.003 or greater"
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PLC Advice - Home Automation Needs onefineday2010 LIVE PLC Questions And Answers 10 July 31st, 2015 10:43 AM
Rx3i Dual Bus PLC swapping issue adnan_hayat88 LIVE PLC Questions And Answers 2 September 23rd, 2014 03:09 PM
issue with PLC on multiple networks DaleAlanB LIVE PLC Questions And Answers 5 August 24th, 2010 12:08 PM
AB PLC 5/40-E OPC Comm Issue ahnerrj LIVE PLC Questions And Answers 0 May 13th, 2010 04:58 PM
Real World Problem Vietnam Bob LIVE PLC Questions And Answers 8 November 23rd, 2002 03:03 PM
