This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Siemens S5 to A-B Control Logix Conversions
Does a utility exist to accomplish the subject subject?
Is it a brute-force affair? I've got a client with a 10+ yr-old S5 utility who wants to upgrade to Control Logix, yet has no functional spec. The existing S5 code is uncommented. I/O is adequately documented, but I'm leery about the invisible and locked Function Blocks. Thanks in Advance, John |
#2 |
There exists no such tool.
Brute force is not a good idea either. There will be mistakes and things that just cannot be translated. The solution is to understand what the program should do, not what it does. Understand the machine/proces/plant and then write a functional description. Then make a completely new ControlLogix program based on the description. If you must write some ControlLogix code based on the old S5 code, then try to switch it to LAD display (aka KOP). It will help a little.
__________________
Jesper
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Siemens S5 and S7 Key Disks | sectoreng01 | LIVE PLC Questions And Answers | 47 | November 25th, 2008 01:56 AM |
| Siemens S5 cpu problem | MagCarb | LIVE PLC Questions And Answers | 13 | June 15th, 2007 07:34 AM |
| Siemens S7 PID Control Problem | qee | LIVE PLC Questions And Answers | 27 | May 15th, 2007 10:53 AM |
| Can I program the old Siemens S5 with Step 7? | Anibal Hernandez | LIVE PLC Questions And Answers | 4 | April 12th, 2004 04:35 PM |
| Panel View & Control Logix | gizmo | LIVE PLC Questions And Answers | 8 | September 21st, 2002 09:52 PM |
