This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
If you're really looking to learn about PLCs, you NEED our book... "Your Personal PLC Tutor - A Guide to Understanding PLCs" Easy to read and uses 'plain' language!
Thread Tools | Display Modes |
#1 |
Connecting OP7 to Siemens S5 PLC
Does anyone know where I can get those files that you install when running an OP7 from an S5 plc. The files are: PLC TYPE FILE NAME AG 90U, AG 100U (CPU 100, CPU 102) S5TD02ST.S5D AG 95U S5TD03ST.S5D AG 100U (CPU 103) S5TD01ST.S5D AG 115U (CPU 941 - CPU 944) S5TD50ST.S5D AG 115U (CPU 945) S5TD51ST.S5D AG 135U S5TD24ST.S5D AG 155U S5TD69ST.S5D I did have a disk with them on but seem to have mis-placed it. I've tried searching google but no luck as yet. Anyone got a copy they could email me? Cheers JT
__________________
I'm beta testing life... |
#2 |
Sorry the filename thing got all messed up...
Here it is again...
__________________
#3 |
Hi JohnnyT,
Attached you will can find what you need. |
#4 |
fribeiro
Brilliant mate. That's just what I was after. Thanks again!
__________________
#5 |
![]() Join Date: Sep 2005
connecting Simatic S5 090U to OP7
Does any body know the cable config to connect Simatic S5 090U to OP7
I need to know the DB15 pin out for the cable. Thanks Dau |
#6 |
![]() Join Date: Aug 2004
look in Appendix D of this manual for the OP7 interface pin-out:
http://support.automation.siemens.co...iew/en/1145112 |
#7 |
#8 |
looks OK
for info.... AG(PLC) pin-outs: 2 = TTY IN- 6 = TTY OUT+ 7 = TTY OUT- 9 = TTY IN+ |
#9 |
![]() Join Date: Apr 2009
Hello
There is a"S5100U CPU102"and an"OP7" that we have problem in their communication,we have used"FB51"whitch has been in"S5TD02ST.S5D"file as you have mentioned in one of your answers,and"DB51"with 256 word and have initiated DW40 of DB1 with KF+1 in OB21 and OB22, and we have assigned DB51 to"INTERFACE AREA"of OP7 in Protool configuration software,but unfortunately we have encountered with the message"NO PLC PRESENTS"Message on OP7.Of course it's necessary to mention that the connection cable has been assembled as in"AS511 e.pdf,as you have mentioned too.Could you guide us in this problem? Best Regards Ali-Mohammadi |
#10 |
Hello
There is a"S5100U CPU102"and an"OP7" whitch we have problem in their communication,we have used"FB51"whitch has been in"S5TD02ST.S5D"file as you have mentioned in one of your answers,and"DB51"with 256 word and have initiated DW40 of DB1 with KF+1 in OB21 and OB22, and we have assigned DB51 to"INTERFACE AREA"of OP7 in Protool configuration software,but unfortunately we have encountered with the message"NO PLC PRESENTS"Message on OP7.Of course it's necessary to mention that the connection cable has been assembled as in"AS511 e.pdf,as you have mentioned too.Could you guide us in this problem? Best Regards Ali-Mohammadi |
#11 |
CD07__01.dxf
Just in case.. |
#12 |
Hello
Thanks for your attention I received your answer,as you had mentioned type of op7 is necessary for S5 connection,but our op is"6AV3 607-1JC30-0AX1 OP7-DP12"therefore it ought to be connected,Is there any other reason for this problem? Best regards Ali-Mohammadi |
#13 |
Hello everybody
Who can guide us how we can read and download both PLC and NC programmes of sinumerik 840D? best regards Ali-Mohammadi |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Question in programming Siemens PLC | stevenPLC | LIVE PLC Questions And Answers | 0 | September 18th, 2004 09:30 AM |
| Siemens S7-400 PLC communication | Jing Zhi | LIVE PLC Questions And Answers | 2 | September 1st, 2004 06:32 AM |
| SIEMENS S5 - Programming port damaged !! | ayman metwally | LIVE PLC Questions And Answers | 2 | August 19th, 2004 11:08 AM |
| Siemens S5 with Prolinx, trending using RSTrend ! | ckchew666 | LIVE PLC Questions And Answers | 0 | December 9th, 2003 12:20 AM |
| profibus network between Siemens S5 and S7 PLC | Leonardo | LIVE PLC Questions And Answers | 3 | June 25th, 2002 09:05 AM |
