Problem in reading electric diagram.
gdalianis
Jan 2008
Greece
17
I have this control IO port on a machine panle. I know a little of reading electrical diagrams. Could some friend help me about it. I can not understand where the machine can supply current as a source and where it must be supplied from an external source. Is it correct that the port supplies voltage to the inputs with A12 common? Is it also correct that the port must be supplied from an external source at output terminals B1 to B12 in order for the outputs would function properly?
What does it do?
Looks to me like you can just use dry contacts on the inputs A1-A11
Your outputs would be depending what you are doing with it
The outputs are photo-coupled darlington pair transistors and basically provide a current connection to the common. So, for a relay or light, one connection would be to your supply and the other (the common) is connected to the output terminal.
The voltage is applied to the far side of the relay coil, then the other side of the coil connects to the digital output terminal.
Hello everyone, this is my first time asking for help here, so please bear with any problem my english or lack of experience can cause. i have a...
2,685
Hi im trying to read/write from excel-rslogix. Sometimes works correctly but other times doesnt work and in excel cells i reg #DIV/0! or REF. I...
1,341
Hello, I faced a problem related with a PLC tsx1720 which appears unresolvable.Even tough,I can manage to connect to it,I am not able to read out...
1,800
Hi there everyone, I`m currently working on a Toshiba drive with ASD-G9ETH communication card on it, this drive is linked on our network. So...
2,807
hi how can i read string type data from registers by citect? i have defined a variable tag in form of strip type and assigned it to an object in...
1,702
