Task monitor 3.1 to L32
TheWaterboy
May 2006
-27.9679796,153.419016
1,924
Logix5000 Task monitor will crash when I point it at anything. It loads symbols etc but then after it displays it all it crashes. Pointing it at PLC's with v20 firmware if that matters.
I have my answer...
Logix 5000 Task Monitor tool v3.4.x.x and all prior versions are not compatible with engineering workstations that have v30 or greater of Studio 5000 Logix Designer installed.
Logix 5000 Task Monitor v3 is not supported with Microsoft .NET Framework 4.6 and greater.
Workaround
Install Logix 5000 Task Monitor tool v3.4.x.x on an engineering workstation or virtual image that does not have v30 or greater of Studio 5000 Logix Designer installed.
Alternatively, uninstall:
• Studio 5000 Logix Designer v30
• RSLinx Classic v3.90
• FactoryTalk Services Platform v2.90
• Microsoft .NET Framework 4.6
Next, install RSLinx Classic v3.81 and FactoryTalk Services Platform v2.81.
So to make this work - uninstall the current version of Studio. Great... just great.
Hello, I have trouble understanding the "Comms" part in the CPU usage pie chart showing in RSLogix Task Monitor Per the RSLogix Task Monitor...
893
Hi all, IÂ’m trying to monitor an L8 processor using Task Monitor. I realize the original Task Monitor isnÂ’t used for the L8 processor, so I...
1,525
Rslogix/Compaclogix system While monitoring a liquid transfer from a flow meter and using RSLogix on-line to watch what was happening, I noticed...
1,230
Is there a way to get the data about the CPU Usage into our HMI? I see that Rockwell can read the task scan time and the configuration time...
1,712
Hi. I have a L85E CPU with FW 28.12. I can see the CPU in Linx but when I select it in the Logix Task Monitor v 3.4.1.0 I am not able to start...
6,225
