Interview question !!!
Mar 2017
6 October
69
i was in an interview and i got this question
what is pointer in S7-300 ?
what is it used for ?
can you do a simple project with it using ladder ?
my expression was :whistle::rolleyes::unsure:
how can u do a number of 20 conveyor start/stop ?
i said i can do it with FC or FB but this will creat a DB for each and then call it in OB1
What is a pointer used for normally? To programmatically loop through data, in this case, it can be DBs, internal memory, peripheral memory, etc... there is also something to say about creating a pointer in Simatic which is anything but easy and I doubt anyone knows this by heart without a sheat sheet.
If the conveyors are controlled each by a separate PLC, you can multicast the command. You can broadcast as well, but it's not as elegant of a solution.
i think i didn't get the answer
i can find pointer in FC and FB ( variable table - selection on data type )
and the answer of the conveyor i think my answer was good but he ask the question may be it's related to the pointer :confused:
This is maybe off topic, but I just had an interview at Amazon and was asked to do this question. I was blanked in the head, was wondering if...
3,814
I'm tasked w/ coming up w/ interview questions for my customer for a plc programmer. I have tons of ideas, but I am afraid I may tailor them too...
53
10,285
What is the maximum integer unit for analog input of siemens 300 plc? pls help thank u in advance.
3,915
I was just reading an old revived thread on here regarding the answer to an interview question. It got me wondering what's the most ridiculous...
5,575
