DC supplies for loop power
godfrey
Apr 2002
Charlotte, NC
412
With control panel design being one of my duties, I can't help but snoop in other peoples cabinets when I am on site commissioning mine. I have noticed that some cabinets use linear power supplies for loop power. I prefer switching supplies. I haven't had problems. What's your preference?
Usually I use switching supplies as well. Generally just the 24V control voltage.
I did have one application using some linear position sensors that seemed to have a problem with excessive noise on the switching power supply. In this case I used linear power supplies, one per unit.
This was a one off fix for a unique problem with a poorly designed (EMF) wise board and a cheapo switching power supply.
Same line, different board 100m away with a better quality power supply (Siemens), same linear position sensor, no problems.
Doug
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
107
is this possible? i have a customer has has a large factory, he has 2 x 800amp supplies coming into the site and would like to switch between...
919
Hey Guys, Can anyone recommend a P/N for 48VDC input, 12VDC output power supply. I tried looking up Phoenix Contact/ RHINO, and wasn't able to...
1,482
Is there any problem with connecting two or more 24V DC power supplies in parallel to get more Amps? I have one 40A supply on a large machine...
21
7,389
Hi all, I was hoping someone could tell me if there's an advantage between using PULS or AB power supplies that are rated for SELV and PELV? I...
1,980
