plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 10th, 2017, 02:41 PM   #1
one2go
Croatia
one2go is offline
DB work orders to PLC
Hello everyone,
I would like to hear how should I start doing my project, step by step instructions if possible. This is my 1st project like this.
Project: PLC recieves work order (recipe or something with attributes(work order number, pallet size, number of lvls that can be filled on pallet, number of pallets...) from customers SQL database program. After that I have to procces those informations and based on that make program that will control robot.
PLC has to reply back to server when task is done.
Is this possible to do?
How to communicate with database and get those informations in PLC program?
How to return answer with filled informations back to database so customer will be informed that task is done?
Im not looking for any kind of code, just need someone to put me in right direction with this project. What to do 1st, what do I have to care about and stuff like that.
Thanks forward.
Old September 10th, 2017, 03:14 PM   #2
labeledas
Canada
labeledas is offline
labeledas's Avatar
what type of plc and is there an hmi?
I have done something similar with a AB controllogix and factorytalk SE.
basically factorytalk would poll a database get setup data and push it to the plc
Old September 10th, 2017, 05:23 PM   #3
ASF
Australia
ASF is offline
There are a few threads on this forum to do with interfacing PLC's and SQL databases. One recommendation that comes up regularly - though I've not used it myself - is Ignition SCADA. It has an SQL bridge module.
I have also used the Oldi eATM ControlLogix hardware module, which was extremely easy to set up - I had data to and from the SQL database in under an hour. Not cheap though!
There are plenty of other ways to do it, but in most cases you're better off going with a more expensive tried and proven method than trying to put something together yourself from scratch - your sanity will thank you for it!
Old September 10th, 2017, 05:34 PM   #4
curlyandshemp
Canada
curlyandshemp is offline
curlyandshemp's Avatar
I beleive Inductive Automation's Ignition Transaction Groups are the easiest way to get SQL data to/from a PLC
__________________
Work to Ride,
Then Ride to Work
I would rather have a bottle in front of me..
than have a frontal lobotomy
Old September 10th, 2017, 06:12 PM   #5
damica1
United States
damica1 is offline
Ignition "Inductive Automation"
__________________
David M. Camp
Marshall Electric / https://mei-tech.com/monitor-and-control
Please Download from our download section "Monitor and Control" .pdf.
Old September 10th, 2017, 08:40 PM   #6
Phrog30
United States
Phrog30 is online now
I agree with ignition, but also think advancedhmi is an option.
Old September 10th, 2017, 11:03 PM   #7
one2go
Croatia
one2go is offline
it would be siemens s7 1200 and yes some hmi too
Old September 10th, 2017, 11:25 PM   #8
sigmadelta
Canada
sigmadelta is offline
WinCC Advanced RT
https://support.industry.siemens.com...dti=0&lc=en-WW
__________________
Freelance Automation Programmer
Old September 11th, 2017, 02:09 AM   #9
Manglemender
United Kingdom
Manglemender is offline
I've done this sort of thing before with a SAP system. The SAP system exported orders to a text file in a defined format. Using the SCADA, (RSView32) The operator could then select an order to process (directory listing in orders folder). The text file would be read in via VBA and built into a work order list for the PLC. I have done similar things in WinCC too.
Nick
Old September 11th, 2017, 03:38 AM   #10
one2go
Croatia
one2go is offline
Quote:
Nick
Can you describe how you done that in winCC?
I cant imagine how do I get exact table from database to database in PLC program. (field to int variable in PLC)
Lets suppose that work order are being added from user side on server PC, then PLC has to scan every xx time and check if there is new, or next order that has to be executed...
Local operator will choose which work order will be executed from HMI.
If im saying something wrong please correct me.
thanks.
Old September 11th, 2017, 04:39 AM   #11
Manglemender
United Kingdom
Hi, I used VBS to read a text file but I understand you can query a DB directly. I've queried DBs directly from Excel but never from a SCADA but the process must be similar.
The text files must be in a defined format for example the first 8 characters on a line might be a product code, the next 5 characters might be height, the next 3 chars quantity and so on.
When a line is read from the file, the string is chopped up and the data converted to tag data or added to an array of data in memory.
The VBA routine below reads a sequential file into an array:
Code:
Public Sub ReadPunchlist()
Dim fName As String, PathName As String, Mark As String
Dim Result, Dist, Punch
On Error GoTo ErrHandler
  If (PathPunchlist = "") Then Call UpdateFilesPathConstVB
   PathName = PathPunchlist & "Punchlist.txt"
  fName = Dir(PathName)                   'Read first file name (if exist)
If (fName <> nullstring) Then
'Read file
Open PathName For Input Access Read Lock Write As #1   'Open Text file in Sequential mode for Reading, Locking write
    'read the data
    ReDim Punchlist(0)
    i = 0 'UBound(PunchList)
    Do While Not EOF(1)
            i = i + 1
            ReDim Preserve Punchlist(i)
            Input #1, Dist, Punch, Mark
            Punchlist(i - 1).Distance = CInt(Dist)
            Punchlist(i - 1).Punch = CInt(Punch)
            Punchlist(i - 1).strPrint = Mark
    Loop
Close #1
End If
Exit Sub
ErrHandler:
  Close #1
  gActivity.Log "VBSub:WkList.ReadPunchlist error: " & Err.Number & Err.Description, roActivityError
  Err.Clear
End Sub
The example above is taken from an RSview project but you can do the same sort of thing with VBS in WinCC. Using scripting, you can also read and write tag values.
File Type: txt Punchlist.txt (679 Bytes, 4 views)
Old September 11th, 2017, 05:00 AM   #12
one2go
Croatia
one2go is offline
Code:
'Read file
    'read the data
    ReDim Punchlist(0)
    Do While Not EOF(1)
            i = i + 1
    Loop
Close #1
End If
Exit Sub
ErrHandler:
  Close #1
  Err.Clear
End Sub
okay thanks, its a bit brighter to me now.
Is it possible to read DB data with GET instruction? and write with PUT? or thats only for communication between M/S PLC?
thanks
Old September 11th, 2017, 12:19 PM   #13
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
http://accautomation.ca/now-you-can-...r-free-part-1/
The above is part 1 of a series called robust data logging for free.
Now You Can Have Robust Data Logging for Free
(PLC Program – Modbus TCP (VB6) – Access Database – Web Server)
Part 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 / 11 /12
The actual reading/writing from the database to the PLC can also be done by AdvancedHMI.
https://sourceforge.net/projects/advancedhmi/
There may be some information in this that can help you.
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old September 11th, 2017, 12:48 PM   #14
keithkyll
United States
keithkyll is offline
Quote:
I cant imagine how do I get exact table from database to database in PLC program. (field to int variable in PLC).
Local operator will choose which work order will be executed from HMI...
Take a look at the "Recipe" function in Win CC. Look at some examples on the Siemens website. Most of the stuff you want to do will be automatic. Use VBS if you need to customize anything. I used VBS to do the datalogging, because the built-in functions were lacking. That was with V12.
Old September 11th, 2017, 02:16 PM   #15
one2go
Croatia
one2go is offline
(PLC Program Modbus TCP (VB6) Access Database Web Server)
Regards,
thanks, will take a look
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Dynamic choosing DB in PLC STEP7 Sergihno LIVE PLC Questions And Answers 31 December 16th, 2016 07:53 AM
How does an PLC interrupt actually work? sommers9 LIVE PLC Questions And Answers 5 April 5th, 2016 02:10 AM
Store orders in PLC with HMI DhoTjai LIVE PLC Questions And Answers 3 March 19th, 2015 10:27 AM
PLC with GSM modem how to work together ? Robustel LIVE PLC Questions And Answers 4 January 23rd, 2013 11:45 PM
Log DB data from a S7 PLC with MPI bibistick LIVE PLC Questions And Answers 5 June 17th, 2008 07:32 AM
