plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 25th, 2017, 12:01 PM   #1
qwemx
India
qwemx is offline
qwemx's Avatar
Post TIA V13 Controlling Drive from S7-300
Hello Experts
I have a simovert VC drive which has a CBP2 card , I have installed the gsd of the CBP2 card and configured it with PPO3 .
now i want to write program for communication my question is - which instructions i have to use ,
is it DP_send and DP_receive ????
program is on dropbox link
https://www.dropbox.com/sh/dl5n2amhr...vtCKdCJxa?dl=0
Old September 25th, 2017, 12:08 PM   #2
JRW
United States
JRW is offline
JRW's Avatar
you have to use ppo3?
Old September 25th, 2017, 12:16 PM   #3
qwemx
India
qwemx is offline
qwemx's Avatar
Quote:
Yes i will be using PPO3
Old September 25th, 2017, 12:23 PM   #4
JRW
United States
JRW is offline
JRW's Avatar
got an e mail address I can send your file back to?
PM me
Old September 25th, 2017, 12:26 PM   #5
qwemx
India
qwemx is offline
qwemx's Avatar
i have sent my email address to you please check your messages ,Thank you
Old September 25th, 2017, 12:37 PM   #6
JRW
United States
JRW is offline
JRW's Avatar
file sent
Old September 27th, 2017, 06:18 AM   #7
qwemx
India
qwemx is offline
qwemx's Avatar
file sent
In this example i selected PPO2 and there are input and output addresses , what are these ?
are these set automatically ?
when reading from the slave which addresses i use and similarly for writing to slave which addresses i use ??
Old September 27th, 2017, 06:31 AM   #8
JRW
United States
JRW is offline
JRW's Avatar
PPO2 uses 6 works of process data PZD and 4 words of parameter data PKW.
What parameter data or P's in the masterdrive do you need to write to?
And why?
Last edited by JRW; September 27th, 2017 at 07:25 AM. Reason: Mixed up my pkw and pzd data
Old September 27th, 2017, 06:36 AM   #9
qwemx
India
qwemx is offline
qwemx's Avatar
PPO2 uses 6 works of process data PKW and 4 words of parameter data PZD.
And why?
i want to send a control word , a speed set point and Torque limit to the drive
after that i receive six values from drive which will be actual speed , actual torque , status word , dc bus voltage and two more , i will display these on an HMI will work on that part once i can run the drive
Old September 27th, 2017, 06:47 AM   #10
JRW
United States
JRW is offline
JRW's Avatar
The FB I sent you does all that. Have you tried to implement it?
Old September 27th, 2017, 07:08 AM   #11
qwemx
India
qwemx is offline
qwemx's Avatar
i was gathering more understanding i will certainly use that
Old September 30th, 2017, 10:23 AM   #12
qwemx
India
qwemx is offline
qwemx's Avatar
Hello
in the DPRD_DAT
Record := P#DIX98.0 BYTE 12
Please explain the part in Bold , is it pointing to the Data block ? data blocks are addressed as DB but here it is DIX , and what does 98 means in DIX98
Old September 30th, 2017, 03:19 PM   #13
boneless
United States
boneless is offline
I should wait for JRW to answer, but this is a pointer, addressing internal bytes of the DB that is currently opened.
Old September 30th, 2017, 03:34 PM   #14
qwemx
India
qwemx is offline
qwemx's Avatar
I studied the Program and found answer to my question ,
This is an instant DB tied to a function block and the data (DPRD_DAT) is saved starting from offset 98.0 and further to 12 byte starting from there
I am trying to write the same program and I find that when I add more local variables the offset keeps changing and therefore either i should define all the local variables before i start writing the code in FB or i can change the address (where to save the control word and rest of the PZD ) once i am finished with the Program .
Last edited by qwemx; September 30th, 2017 at 03:42 PM. Reason: adding information for clarity
Old September 30th, 2017, 04:02 PM   #15
qwemx
India
qwemx is offline
qwemx's Avatar
JRW, can you please explain this ? the bits are not sequenced as they appear in the Control word ,
CALL DPWR_DAT
LADDR :=#DriveAddr
RECORD :=P#DIX86.0 BYTE 12
but the write instruction will write 12 bytes starting from offset 86.0
I believe the control word Bits are specific and each bit mean something and what they represent can not be changed
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
TIA Portal V11 S7...Flex and compatibility Bedhes Putih LIVE PLC Questions And Answers 27 June 27th, 2016 10:52 AM
TIA V13 SP1 keeps crashing!! Traloch LIVE PLC Questions And Answers 2 September 21st, 2015 09:11 AM
Connecting Siemens S7 300 with digitax STBasic Servo Drive osamamalhy LIVE PLC Questions And Answers 0 March 24th, 2015 11:48 AM
Abb Ac Drive rajendrad LIVE PLC Questions And Answers 13 November 5th, 2006 10:18 AM
AB Drive Tools(V2.06) W/SC 300 Interface Vietnam Bob LIVE PLC Questions And Answers 0 November 20th, 2002 09:19 PM
