plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 12th, 2017, 10:26 AM   #1
Aggregateman
United States
Aggregateman is offline
CHEAP remote “push button” solution?
Hey everyone! Let me start by explaining what I want to do here, I’ve got a small PLC system and am looking for a cheap way to rig up a compact remote system to trigger a couple non-essential input controls, kind of a “well that would be nice to have but we don’t want to spend tons of money” deal. I’ve got several points where I would put remote receivers and be controlled by the same remote, I only need 2 maybe 3 buttons, and it doesn’t need to be more than 100ft of range from each point(although more range would be a plus), currently I’m thinking of these “universal keyless entry install kits” off of amazon (see link below) but I’m wondering if anyone here has any other suggestions as to a good relatively inexpensive solution?
Preferably operating and switching 12vDC
Thanks!
FICBOX Universal Car Door Lock Vehicle Keyless Entry System Auto Remote Central Kit with Control Box https://www.amazon.com/dp/B01HB5M5R2..._4133zbR61ZHBW
Old October 12th, 2017, 10:30 AM   #2
harryting
United States
harryting is offline
harryting's Avatar
That should work. I used something similar to retrofit an old garage door opener once.
Old October 12th, 2017, 10:36 AM   #3
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
What PLC are you working with?
For fun not too long ago, I bought a couple of amazon dash buttons and got them to write to a tag in a CompactLogix PLC. The basic idea is there is a python script running on a PC (or Raspberry Pi), listen for the button press, when we see it's MAC ID, write to a PLC tag. I'm sure the same thing could be done with a PLC that supports Modbus too since there are modbus libraries out there. Just a thought.
Old October 12th, 2017, 10:38 AM   #4
Aggregateman
United States
Compactlogix with remote I/O scattered around, that dash button sounds interesting, what kind of range did you have?
Old October 12th, 2017, 10:40 AM   #5
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
I haven't tested the range, the farthest I'd guess that I was away from my router was 60 feet. It's not to say that farther wouldn't have worked, I just didn't try it. I'll see if I can try it today. I still have it around here somewhere.
Old October 12th, 2017, 10:59 AM   #6
AustralIan
United Kingdom
AustralIan is offline
Does the dash button automatically order toilet paper when you hit the stop button?
Old October 12th, 2017, 11:08 AM   #7
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
For my home control PLC's I bought a couple of these - they all operate on the same frequency, so one transmitter can talk to both receivers that are not within the same range. At $4.00 per set they were cheap enough to play with. They are RF so it will work through walls and from outside.
I wired the 4 outputs to a SLC TTL input card, but the receiver gives PNP outputs and the AB TTL input is sourcing, so all 4 are on all the time, one (or more - it can send multiple signals at once) goes low when the button is pressed.
I programmed it to select 1 of 4 modes, then the next press(es) perform 4 functions in the mode selected. After 12 seconds of no input I go out of the selected mode for selecting another mode. When a mode is selected I turn on a night light in the window of the room, that goes out when the mode drops.
http://www.ebay.com/itm/DC-5v-4CH-Ch...QAAOSwoBtW1~3o
Old October 12th, 2017, 12:28 PM   #8
RClem
United States
RClem is offline
RClem's Avatar
I've used these, good range, no batteries.
https://www.schneider-electric.com/e...-harmony-xb5r/
Old October 12th, 2017, 12:47 PM   #9
daba
United Kingdom
daba is offline
daba's Avatar
I'm intrigued....
The transmitter is described as ...
Energy efficient
due to non-current
consuming
transmitter
.... sounds like a bit of magic !!
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old October 12th, 2017, 06:09 PM   #10
ASF
Australia
ASF is offline
I've tried those out too, they're brilliant. The buttons generate their own power using the piezoelectric effect (I believe) - basically - they capture the kinetic energy of you pressing the button and use it to transmit their signal.
We put my boss in a car and sent him down the road to see how far he could drive before they lost connection. He was out of sight before it stopped working.
Old October 12th, 2017, 06:37 PM   #11
Aggregateman
United States
WOW, that’s impressive, I’m going to have to see about getting some of those, but those have to cost a pretty penny. Guess I’ll call our Schneider supplier in the morning!
Aside from that I still need the keyfob style solution so we can keep them on our key rings, carrying around a push button wouldn’t be quite as practical... haha!
Old October 12th, 2017, 06:53 PM   #12
justblaze
Supporting Member
United States
justblaze is offline
They do have a little bit smaller units.
https://www.schneider-electric.com/e...007%29%29#tabs
I have had good luck with the standard buttons and receiver. I did have to use the relay antenna as the received was mounted in a metal enclosure and range wasn't great.
Old October 13th, 2017, 03:03 AM   #13
chud
South Africa
chud is offline
chud's Avatar
Regarding the schneider buttons. If you mount them in an enclosure you loose a lot of range. So as mentioned above better to get a relay antenna. Also it is just better to buy the programmable receiver from the get go. If you lose the button with the normal receiver you have to buy the set again as they are paired with each other and no way to pair a new button. But I love the fact that no batteries are needed.
Old October 13th, 2017, 06:56 AM   #14
AustralIan
United Kingdom
Does anyone know about the security of these pushbuttons?
Like, can they be scanned and mimicked by someone within 100m of the receiver, or does it have some sort of security protocol?
Old October 13th, 2017, 09:52 AM   #15
RClem
United States
RClem is offline
RClem's Avatar
Per the catalog page:
http://download.schneider-electric.c...0Rev.%2002.pdf
The Harmony wireless, batteryless push button product range enables remote
control of a relay (receiver) by means of a push button (transmitter). The control is by
radio transmission, where the transmitter is fitted with a ‘‘dynamo’’ type generator
that converts mechanical energy – produced when the push button is pressed – to
electrical energy. A radio-encoded message with a unique ID code is sent as a single
pulse to one or more receivers located several dozen metres away (see figure A). A
single receiver can also be actuated by up to 32 different transmitters (see figure B).
Depending on the application, a relay-antenna can be used to “transmit around” an
obstacle that impedes transmission, or to increase the range (see figures A and B).
The possible distance (1) between a transmitter and a receiver is approximately:
- 100 m/328 ft where there are no obstacles,
- 25 m/82 ft if the receiver is installed in a metal housing or in a closed
metal enclosure,
- 300 m/984 ft if a relay-antenna is located between the transmitter and the receiver
(receiver installed in a metal housing or in a closed metal enclosure).
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Remote HMI solution. Elcan LIVE PLC Questions And Answers 10 April 28th, 2016 09:54 AM
PLC+HMI cheap solution yacineamk LIVE PLC Questions And Answers 17 January 15th, 2016 09:51 AM
Cheap data logging / SCADA solution mikas_m LIVE PLC Questions And Answers 4 December 14th, 2015 11:56 PM
Cheap solution to read temp. on analog in? Icefire LIVE PLC Questions And Answers 10 March 29th, 2007 02:07 AM
Remote controls flukie LIVE PLC Questions And Answers 4 May 26th, 2004 05:58 PM
