Getting a DC input from an AC circuit
sumPLC
Oct 2017
Phoenix, AZ
I am automating a COP tank. If you're not familiar with the term, it's basically a big dishwashing sink. I am using a level sensor to know when to stop filling the tank. The sensor is in a 120vac circuit. When the water gets to the level, it completes the circuit and triggers a relay that controls another 120vac circuit. I would like to use the second circuit as a digital input to the PLC. The best idea I've had is to use a transformer to transform the ac to dc. Is there a better, simpler, cheaper way to do this?
Is your PLC inputs 120vac or 24vdc? If they are 24vdc then just like "g.mccormick" has mentioned. A small 24vdc power supply ($20.00) then if your existing second circuit relay has a spare set of contacts.(Make and Break a 24vdc line through those contacts to an input on the PLC.)
That's about all it should take.
A transformer will not convert AC voltage to DC. You'd need a rectifier to accomplish that.
Two words... Interposing relay.
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,406
I need to spend some money (my own) before the end of the year, and it's about time I got a Scopemeter. I've been looking at the different...
1,821
Hello, I have a Micrologix 1400 PLC and using RSLogix 500. Using a Multi Ranger Ultra Sonic Level Sensor and the input is moved to N7:11, then...
3,885
Dear All, I am new to RSView32 and I am with a problem these days.....For the conveyour safety we have beltsway switches installed and the...
4,410
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
56
