plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 24th, 2017, 04:37 PM   #1
Adam13
United States
Adam13 is offline
Adam13's Avatar
Tia Portal v14 Embed Tag Value in Text List Item
Using Tia Portal v14 and a KTP400 Basic PN, is there a way to embed a tag value into a text list item? I would like to create a selection list using a Symbolic I/O Field but I need the strings in the text list to update based on current tag values on the PLC.
Thank you!
Old October 25th, 2017, 04:50 AM   #2
Thomas_v2
Germany
Thomas_v2 is offline
If you are in edit field "Text" for the text list, you can right click there and in the context menu select "Insert parameter field". A dialog field pops up where you can select the Tag to insert and the data format.
The tag you insert there I'd configure to Aquisition mode continuous. I remember that otherwise it not always got refreshed in the textlist field.
Hopefully that works also with the Basic panels, I've used a comfort Panel.
Old October 25th, 2017, 09:32 AM   #3
Adam13
United States
Adam13 is offline
Adam13's Avatar
Thomas, thank you for the quick feedback. Unfortunately that option does not appear when I right click in the text field. Doing some searching and I found a reference to using the format <Tag : 4, TagNameHere> to embed tag values (4 refers to # of digits). This does not work either so I have to assume tag embedding is not possible on the basic panels.
When editing Alarm text, right clicking does present the option "Insert tag field...". Unless I am missing something the text list function seems to be purposefully gimped in the basic panels. I would have thought this a "basic" function.
Text list right click image
Old October 25th, 2017, 10:03 AM   #4
Thomas_v2
Germany
Just tested it, it seems that it's not possible with a Basic Panel. Even not with the newer ones with V14 firmware like KTP700 Basic.
You must be really careful when selecting the basic panels, these things are really gimped as you say.
I had a project where I had to replace an absolute basic text based WinCC flexible panel which was used only for alarming. But the basic panels can't handle the number of alarms the old cheap one had supported.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
TIA Portal V14 Slice access grnick50 LIVE PLC Questions And Answers 15 December 27th, 2016 09:22 AM
License for TIA Portal ( from S7 to TIA ) Oliver Micka LIVE PLC Questions And Answers 2 November 29th, 2016 07:40 AM
Simulate 1200 screen in TIA portal Siemens Step7 dahnuguy LIVE PLC Questions And Answers 26 June 6th, 2016 04:11 PM
Siemens OP77B Trouble in TIA Portal Tim James LIVE PLC Questions And Answers 4 December 24th, 2012 03:27 PM
WinCC Flex - Text List juanmdx LIVE PLC Questions And Answers 7 September 22nd, 2007 04:52 AM
