plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 4th, 2017, 05:10 AM   #1
Combo
Belgium
Combo is offline
Little problem with the minus sign to send position to a servo controller:
I have a Little problem with the minus sign.
The actual postion works fine but the send position doesn't arrive well in the drive.
So, my code for the actual position is:
Code:
        #TEMP_VARS.REC_POS_DWORD := ROL(
                                   IN := #PN_POS_ACT_D,
                                   N := 16);
                                   #TEMP_VARS.REC_POS_DINT := DWORD_TO_DINT(#TEMP_VARS.REC_POS_DWORD);
                                   #STD.RESULT."GRAPH RET"."ACT POS" := DINT_TO_REAL(#TEMP_VARS.REC_POS_DINT) / 10.0;
This works perfectly, when I control the axis manually below zero, this is correct.
But when I send with the following code to the drive, the position is the drive below zero is completely rubbish:
Code:
        #PN_POS_SET_D := ROL(
                             IN := DINT_TO_DWORD(ROUND(#STD.CMD."GRAPH CMD"."POS SET" * 10.0)),
                             N := 16);
I allready tried conversion from REAL_TO_DWORD, but that wasn't a succes either.
Owyeah, the ROL is because there is a word swap, the drive is a Lenze.
Any ideas ?
Thanks,
Gerry
Old November 4th, 2017, 06:32 AM   #2
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Nothing wrong with your code with the test data I used.
Set a known position of -0.2 which converts to FFFEFFFF for the data you send to the drive and should be FFFFFFFE in the drive. Compare this bit pattern with the "rubbish" you see in the drive - there must be a correlation that you can see.
Old November 5th, 2017, 04:34 AM   #3
Combo
Belgium
Combo is offline
Hello
Hello,
An amazing thank you for doing the test. Yes I will do the test with minus 0,2 tomorow. Thanks for the advice. I'll give feedback here afterwards, thank you.
Kind regards,
Gerry
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
QJ71E71-100 Send Data Problem ball261 LIVE PLC Questions And Answers 0 December 29th, 2009 07:59 PM
compactlogix send ascii messages to alpha sign? jeremyhass LIVE PLC Questions And Answers 4 October 22nd, 2009 05:07 AM
Ultra3000i Dnet moving to preset position problems johnfarrugia LIVE PLC Questions And Answers 8 November 21st, 2007 10:53 AM
Position Feedback with Mitsubishi Servos kpizzolatto LIVE PLC Questions And Answers 1 June 13th, 2007 12:48 PM
Problem with servo controller OMRON HUGO28 LIVE PLC Questions And Answers 1 June 8th, 2005 07:42 AM
