Directlogic250 problem
Buggzy
Nov 2017
Victoria
Hey guys, i have a second hand 250 CPU i'm trying to connect to on my test bench and i cant for the life of me get it to connect.
plc is on with power light green
switch is on term mode
cable is from the automation direct box of cables - port 1 - rj12 lead plugged into a d type serial plug into com1 on pc
serial port is set to com 1
baud rate 9600 - odd
only setting im not sure is the address - i have it on the standard "1"
using directsoft 6 - just keeps saying cant detect plc.
I have tried K sequence and direct net
is there anything i have missed or is maybe the CPU cactus?
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
37
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
46
I have one old Ansaldo VFD from 37kW and it have only sign OFF on the display after put it on the 3x400VAC. Is there any idea, how to solve this...
58
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
497
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
68
