plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 5th, 2017, 08:44 PM   #1
JZerb
United States
JZerb is offline
ZipLink Module Serial Communication
So Im wondering if something is possible with these Zip Link feed through communication modules. If I have one in the control panel, and one out in a remote panel where the HMI is and Iím using it so that the two can communicate, can I plug into the unused port on the Zip Link and connect to the PLC from the remote panel location whilst the HMI is still plugged into the Zip Link as well? Or in order for me to be able to communicate with the PLC from the remote location will I have to unplug the HMI from the Zip Link and then plug my laptop into that port?
Old November 6th, 2017, 06:46 AM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
https://www.automationdirect.com/adc...Complete_List)
What PLC are you using? What communication port and protocol?
Regards,
__________________
Garry
http://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old November 6th, 2017, 11:45 AM   #3
JZerb
United States
JZerb is offline
Micrologix 1200. RS232 DF-1. Using the programmer port on the side of it.
Old November 6th, 2017, 11:55 AM   #4
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
RS-232/DF1 is point to point meaning it only supports two devices. What you are wanting to do is supported by a port splitter from A/B part number 1747-DPS1. I have never used it, but I expect that your cable length will be limited to the RS-232 standard of 50 feet between the controllers.
What ZipLink module did you have in mind?
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old November 6th, 2017, 12:13 PM   #5
JZerb
United States
JZerb is offline
This is the ZipLink I’m using.
https://www.automationdirect.com/adc...t)/ZL-RTB-DB09
Old November 6th, 2017, 01:18 PM   #6
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
I don't think that will work for you with three nodes connected at once. Using it as a terminal block interface between the PLCs should be fine and make for a professional termination. I think you will find that you need to unplug one PLC in order to connect your laptop to the other. The A/B port splitter has active electronics to enable it to "cheat" the electrical and protocol limitations.
In order to truly network the Micrologix 1200, if you have the budget, look at the Digi One IAP. It is a DF1 compatible serial to ethernet converter. This would allow the use of your PC and other devices like HMIs to all be connected to both PLCs. You would need two of them and they run about $400 each.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
MicroLogix 1400 RTD Module Jason Ozolins LIVE PLC Questions And Answers 8 June 14th, 2016 02:12 PM
Generic Ethernet Module communication status Lovell LIVE PLC Questions And Answers 4 May 13th, 2016 12:43 PM
serial communication between Siemens PLC and Arduino milan12 LIVE PLC Questions And Answers 13 September 11th, 2015 10:54 AM
URGENT: MicroLogix 1200 Serial Communication on Serial jawad rasool LIVE PLC Questions And Answers 11 May 24th, 2015 10:54 PM
slc 500 Problems with serial communication dms1808 LIVE PLC Questions And Answers 6 February 18th, 2009 06:38 AM
