Auto Switch Schematic Symbol
theColonel26
Feb 2014
West Michigan
785
I would like to know if anyone knows of a proper schematics symbol to use for a 3 wire magnetic auto switch. This is the kind of switch you would use on a pneumatic cylinder to detect position.
I have used a standard prox sensor symbol in the past but I was wondering if there is something better.
R3aOz8CFdIAAAAABJRU5ErkJgggA=
Standard Prox Symbol below
I agree with James. To indicate that it is magnet operated, some people put a C shaped magnet symbol above it. I am more inclined to include that info in the description and use the standard prox switch symbol.
I think this one is IEC and yours is JIC, but I didn't find a JIC version with the magnet in a quick google search:
http://www.electrical-symbols.com/i...es-sensors-field/contact-proximity-magnet.png
Like all of the previous replies, I agree that symbol is foe a prox switch. I’m not sure what you mean by using the word “auto” though.
Not specific, but may give you some ideas for creating your own symbols...
These are IEC symbols, but may be of some use to you??
Rob
Yikes, I would really be scratching my head about that one. "what is that"?
Because switches are usually called out in the mechanical BOM, as others have pointed out, I've never used anything other than a limit switch or prox symbol and have never been corrected by a customer (some are pretty picky too).
Not sure what you are looking for
This is a type of auto switch they tend to very on how they are in the schematic depends on the type of auto switch.
This better?
Hello, We are to build a panel where there is two externat power supplies for redundancy. 400V 20 Ampere. One primare and one seccondary. If...
1,886
can anyone ..guid me the auto /manual switch wiring digram so that, I can use plc for auto and mnual purpose.....seperately...
4,517
I am writing this ladder for a competence test. The outputs seem to over ride each other and not work. eg when on manual, the auto stops the...
6,839
Aoa i am working on plc project, i want to address the manual auto switch in plc,how we address the auto/manual switch ?can we use only the...
4,203
We use a two position selector to switch our machines from auto to manual mode. In manual, many parts of the machine can be jogged by the...
31
13,433
