plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 6th, 2017, 01:33 PM   #1
AnotherPLCguy
United States
AnotherPLCguy is offline
Assign IP Address to PowerFlex 523
Hello Experts,
I am a newbie in setting up the Allen Bradley PowerFlex drives and need to assign an IP Address to a PowerFlex 523 series drive which has the 25-COMM-E2P adapter - I know there is a way through the HIM on the drive but want to know how it can be done via CCW (Connected Components WorkBench) or RS Logix 5000 ?
Thanks!
Old November 6th, 2017, 02:54 PM   #2
VAN
United States
VAN is offline
If you can access the USB port you could set it up with CCW.
Old November 6th, 2017, 03:16 PM   #3
AnotherPLCguy
United States
Hi VAN, Thanks for the reply! I can access the drive from the USB slot in the back but where in CCW do I assign the IP address ? If I hit the device properties tab, I do not see a communications tab where you assign the IP address. I looked up some videos on youtube which show it for a 525 drive and they show a communications tab where you can change it but 523 drive doesn't show anything like that - see attached image.
Old November 6th, 2017, 03:49 PM   #4
VAN
United States
VAN is offline
Hmm, I don't have a PF523 that I can pull up.
How about opening RSLinx and see if you can access the device properties.
I could also be wrong but from Rockwell it looks like you should be able to configure through the USB port.
edit - If you have access to the parameters you should be able to set these to the IP you want. Also, make sure to power cycle after making the change to make sure the IP stayed (also turn off bootp and DHCP).
EN Addr Sel(1) C128
EN IP Addr Cfg 1(1) C129
EN IP Addr Cfg 2(1) C130
EN IP Addr Cfg 3(1) C131
EN IP Addr Cfg 4(1) C132
EN Subnet Cfg 1(1) C133
EN Subnet Cfg 2(1) C134
EN Subnet Cfg 3(1) C135
EN Subnet Cfg 4(1) C136
EN Gateway Cfg 1(1) C137
EN Gateway Cfg 2(1) C138
http://literature.rockwellautomation...m001_-en-e.pdf
Old November 6th, 2017, 04:04 PM   #5
AnotherPLCguy
United States
With the drive connected to my laptop via the USB cable, nothing shows up in RSLinx for the 523 drive. Yes, I agree with you that from the Rockwell Manuals it looks like I can configure via the USB port but am having difficulties and hence I am here.
Old November 6th, 2017, 04:36 PM   #6
padees
United States
padees is offline
padees's Avatar
LOL, I am sure you will figure it out AFTER you read the manual!
Old November 6th, 2017, 05:01 PM   #7
VAN
United States
VAN is offline
Quote:
Do you have the USB driver configured (this should be in RSLinx) for the USB? (I don't recall this being added automatically.)
Old November 6th, 2017, 05:54 PM   #8
Helliana
United States
Helliana is offline
I haven't used a powerflex 523 with a 25-COMM-E2P, but from glancing at the manual and playing around in CCW, it appears the 25-COMM-E2P has parameters that are completely separate from the parameters in the drive. It looks like the two methods you have to establish initial communication is via the dip switches or bootp. After communication is established, you can connect via CCW and change parameters from there. I do not believe it can be configured directly from the drives configuration in CCW.
The 25-COMM-E2P is added to CCW by selecting "Multi-drive PF52x E2P" in the add device menu with all the drives.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Changing a Panelview Plus IP Address on an existing system Rob S. LIVE PLC Questions And Answers 7 January 10th, 2016 05:37 PM
Using Compactlogix 1769-L36ERM for the first time - Assign IP address grnick50 LIVE PLC Questions And Answers 21 August 17th, 2015 06:32 PM
HELP !!Please Lost PLC COMM richleva LIVE PLC Questions And Answers 18 July 17th, 2015 02:51 PM
1794-AENT Ser.A; How to setup an IP address? boldive LIVE PLC Questions And Answers 2 November 11th, 2008 06:25 AM
Assign IP address sweety616 LIVE PLC Questions And Answers 4 January 23rd, 2006 12:11 PM
