" RS485 serial " or " Modbus Rtu " protocol
RS-485 is just the means of the electrical transmission (it is a balanced signal), Modbus is the protocol at which the DATA is transmitted across the line.
You can transmit/receive Modbus across various electrical schemes
RS-232
RS-485/488
Ethernet
Modbus RTU has specific timing requirements that define the size of a communications message 'packet' and calculates the CRC error checking value.
Converters like these generally have a specific Modbus model with firmware that handles Modbus packets. The firmware is specfically designed to keep a Modbus message packet intact, without splitting it up, it constructs a proper Modbus packet from other data with the correct header and byte count values, and it calculates the CRC error check value for the Modbus packet.
The generic RS-485 is just that, RS-485. It does not hold to Modbus packet size and timing requirements or calculate a CRC value. It just transmits and receives on 485.
I am using a M221 PLC (TM221CE24R) which provides me 1 Rs485 port, which I am already using to communicate with a sensor (Rs485/Modbus). My...
744
I'm using a Lantronix xPressDR+ for serial to ethernet to serial encapsulation to an RS485 ASCII string of instruments. The software part...
1,920
Hello all, I am trying to communicate to a brushed DC motor controller through a 1769-ASCII to a RS485/TTL serial adapter. Part numbers for each...
1,476
I've been searching through the forums to see if I could find this question answered anywhere else without success. My apologies if this is a...
8,849
So I have never setup serial communications before. I am new to this so go easy on me. I have an Omron CP1EN40S1DR-A with built in RS485 port. I...
5,228
