plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 23rd, 2017, 07:09 PM   #1
spaderkung
Sweden
spaderkung is offline
Tropical installations
Have anyone encountered liquid water inside junction and motor boxes as a result of condensation, not leakage? Solutions? An idea is 1 drilled hole in bottom that will allow gravity water out, but stop wind and dust blowing in..
__________________
Jon Bolmstedt, Inspired Automatician.
Old November 23rd, 2017, 07:49 PM   #2
Mickey
United States
Mickey is offline
Mickey's Avatar
Ok, as long as they are not in a hazardous environment.
Desiccant packs or a can(if you have room) with holes drilled in it . See link
https://www.google.com/search?q=desi...hrome&ie=UTF-8
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old November 23rd, 2017, 08:22 PM   #3
GaryS
United States
GaryS is offline
GaryS's Avatar
I have seen that more than a few times. Condensation in a motor only happens when the motor sits idle doe a long time.
you can install external heaters to keep the motor temp up but here is a better solution
http://www.motortronics.com/pages/heatercontrols.html
it works without any additional wiring to the motor
as for the conduit the hole in the bottom of the box is a s good a solution as any as long as it not a hazardous environment.
Old November 23rd, 2017, 08:33 PM   #4
curlyandshemp
Canada
curlyandshemp is offline
curlyandshemp's Avatar
Quote:
Dielectric grease smeared everywhere? Same stuff is used on motorcycle spark plug boots. Stops moisture getting to where it does not belong.
Gel packs ( do no eat label ). Meat packing plants swear by these
__________________
Work to Ride,
Then Ride to Work
I would rather have a bottle in front of me..
than have a frontal lobotomy
Old November 23rd, 2017, 10:05 PM   #5
spaderkung
Sweden
Thanks.
__________________
Old November 24th, 2017, 02:48 AM   #6
rQx
Sweden
rQx is offline
For cabinets and junction boxes you could use:
https://www.rittal.com/com-en/produc...ductID=2459500
If it's a condensation issue
Old November 24th, 2017, 02:55 AM   #7
Ronnie Sullivan
United Kingdom
Ronnie Sullivan is offline
I have seen so many 'weatherproof - waterproof enclosures filled with water that with due considerations to the conditions - I drill a hole where the water gathers.
Better than any watertight seal or gasket.
Old November 24th, 2017, 10:50 AM   #8
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
When I worked in a food processing plant NEMA 4 meant that a box was sure to never let any water out. We drilled holes in them and it helped.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old November 24th, 2017, 11:30 AM   #9
Tom Jenkins
United States
Tom Jenkins is offline
Tom Jenkins's Avatar
For enclosures I've also drilled my share of drain holes. I've even used a hammer and spike to create a hole when a drill wasn't handy - this actually works well because it creates a pitch to the hole.
For motors winding heaters are usually an available option. You just need a relay to put low voltage to the heater when motor power is cut.
For devices like electric motor operators on valves where a drain hole isn't feasible I usually specify a small cartridge heater and thermostat to eliminate condensation. This is also a commonly available option.
Old November 24th, 2017, 12:01 PM   #10
rankhornjp
United States
rankhornjp is offline
Put a T at the lowest point, then flex UP to the device/motor from the center of the T and put one of these in the bottom.
http://www.cooperindustries.com/cont...tiondrain.html
Old November 24th, 2017, 07:43 PM   #11
BinderNut
United States
BinderNut is offline
Like OkiePC, I see lots of those 4x boxes that will let water in but not let it out. A small drain hole helps if it's not in a "hostile" environment.
Yup. T to the lowest spot and install a drain helps.
Also, using duct-seal putty on the other end of the conduit (at the MCC) will help if the MCC is cooler than the plant floor where the motor is.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Anyone with experience of offshore installations? Weo LIVE PLC Questions And Answers 5 February 18th, 2009 09:56 PM
