OMRON FINS OVER TCP CJ2m
FarCry
Jun 2012
Ljubljana
Hello.
I'm trying to communicate between two PLC's using FINS function block _CPU011:ReceiveData.
PLC1: IP 192.168.1.50 (MASTER)
PLC2:IP 192.168.1.51 (SLAVE)
If I don't use »IP Address Table« everything works using NODE number &51.
The problem is that on the real project these two PLC's will be on different subnet.
For example:
PLC2: IP 192.168.2.50
So I will have to use »IP Address Table« to achieve communication between these two PLC's.
I tried to sett IP Address Table on MASTER: Node 1=192.168.2.50
But If I try to communicate I see that packet is sended to network but I've got error #1005.
Do I have to sett the SLAVE IP Address Table?
How to do this?
What are the right settings for MASTER and SLAVE IP Address Table?
I don't want to use CX-Integrator because I would like to make project to UPLOAD and forget.
Thanks.
If I want to do Data Link I would have to buy additional card.
This is not an option since the project allready contains about 25 PLC's.
So I would need to buy 25 units.
Hello, someone have an example of an comunication between an Omron CJ2M CPU33 with FINS TCP to PC? Thanks for help
1,359
Hello people Has anyone managed to perform an arduino communication with an omron PLC through the FINS TCP/IP protocol? I already managed to do...
2,144
Hello Someone know an Function Block or example code for Fins TCP/IP or UDP working for CJ2M CPU33? Thanks for help
1,203
Hi Guys, a few years ago I started to write a little test program for PC to communicate with OMRON PLCs by FINS commands. Well, I would swear...
2,777
Hi, I am writing Omron FINS TCP/IP. I am some bug at my vb program side. I need help. Did someone have the Omron FINS TCP/IP sample program ...
6,577
