plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 24th, 2017, 12:34 PM   #1
sparkytex
Canada
sparkytex is offline
sparkytex's Avatar
Connecting to AB 1769-L32E
Hello All,
I have a 1769-L32E Compact logix processor that I need to connect to. It's sitting on my desk with a power supply attached to it and powered up. I have a desktop with RSLogix 5000 and RSLinx set up on it. I do not have a way to connect to the Processor VIA RS232 9 pin. All I have is an Ethernet patch cord plugged into the Ethernet card on the desktop and processor Ethernet port.
What are the steps I need to take in order to set up a driver in RSLinx to communicated to this processor as I have to load a program onto it as well as download Firmware Rev 17.2 onto it. The desktop has a static IP as its used for an HMI station on the PLC network that I'll be putting this new processor on.
I want to be able to load the program onto this processor and swap it out with an existing one that is already connected to the PLC network and is running.
thanks in advance,
Tex
__________________
Waste Water Automation and Control
Old November 24th, 2017, 12:41 PM   #2
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
When you use Flash you can use Bootp and assign the address to the PLC then flash it
Or you can just get a crossover cable or null modem cable for the RS232
Here is a video I did awhile back that may help...
Allen Bradley 1769-L32e setting up Ethernet and flashing CPU http://youtu.be/FkO2BBuuwJw
Make sure you dont have both CPU's on the network with the same address
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old November 24th, 2017, 01:46 PM   #3
sparkytex
Canada
sparkytex's Avatar
So In order to connect via Ethernet IP driver I first need assign a static IP address to the L32E's Ethernet port with a DF1/RS-232 driver in RSLinx? My issue is I have no way of connecting to the processor via DF1/RS-232 as I have no cables to make that happen.
__________________
Old November 24th, 2017, 01:55 PM   #4
geniusintraining
United States
No, you can open ControlFlash... try to update a L32e with your address you want to flash, after a min it will error out and you can enter in the mac ID, by doing this it will use Bootp and will assign a IP address to the PLC, then you can flash it with using Ethernet IP
You do not need a serial cable but surprised if you dont have one laying around?
__________________
Old November 24th, 2017, 02:03 PM   #5
sparkytex
Canada
sparkytex's Avatar
there isn't a 9-pin port on this desktop nor control flash, so it seems I'm out of luck at this moment. Is control flash free to download, and is it downloaded from Rockwell?
__________________
Old November 24th, 2017, 02:57 PM   #6
geniusintraining
United States
Quote:
Yes and its included with RSLogix 5000 and newer
https://compatibility.rockwellautoma...versions=55875
__________________
Old November 24th, 2017, 08:12 PM   #7
sparkytex
Canada
sparkytex's Avatar
Thank you very much for your help!
__________________
Old November 25th, 2017, 06:38 AM   #8
geniusintraining
United States
Your welcome, hope you got it working
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Connecting AB SLC 5/03 with Siemens HMI VoltSmith LIVE PLC Questions And Answers 12 March 5th, 2016 12:01 PM
AB Pricing Stuntman LIVE PLC Questions And Answers 27 May 18th, 2012 02:15 PM
Connecting AB Micrologix 1000 with PC through AB 1761-NET-ENI module over Ethernet hrauf LIVE PLC Questions And Answers 2 December 12th, 2011 05:17 PM
String, transfer from AB 1769 to PV600 DF1 edwinmart LIVE PLC Questions And Answers 7 May 14th, 2007 08:55 PM
AB - Tyranny! nighthawkjw LIVE PLC Questions And Answers 45 March 30th, 2007 04:31 PM
