plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 25th, 2017, 10:32 PM   #1
anthony.v3a
United States
anthony.v3a is offline
Array searching and inserting data to first available space
How would I search an array of 52 SINTs for an available space (0) then move a (1) into the first available space?
Old November 25th, 2017, 10:48 PM   #2
Bullzi
United States
Bullzi is offline
What PLC are you using? Very important detail.
__________________
There is never enough money to do it right but there is always enough money to do it again.
Old November 25th, 2017, 10:59 PM   #3
anthony.v3a
United States
AB 1756-L72 Version 21. Studio 5000. Haven't found the right combination of anything in the Instruction Reference Manual.
Old November 25th, 2017, 11:09 PM   #4
Bullzi
United States
Bullzi is offline
Look at the File Search and Compare (FSC) Instruction.
You can have that instruction search your array for a 0 (or just about anything). It will return the fist location that it finds that meets your search criteria. You can then write something into that location.
__________________
Old December 4th, 2017, 09:42 PM   #5
anthony.v3a
United States
This seems to work, although I am having some difficulty setting it up properly, everything says that I need to RES the FD or IN bits but when I write the CONTROL.IN bit in the RES instruction I get an ERROR, invalid data type. The only resetting in the RES instruction that doesn't cause an ERROR is just the CONTROL data type. How do I just reset the .DN or .IN bits?
Old December 4th, 2017, 10:01 PM   #6
ASF
Australia
ASF is offline
If you reset the FSC instruction (by addressing a RES command to the Control tag of the FSC instruction), it will reset the .FD and .DN bits as a part of the reset.
You can also turn off the .FD and .IN bits with an OTU instruction, if you wish - an example of where you might do this is if your FSC finds a match, but you want it to continue searching the array for more matches. In that case you'd unlatch the .FD bit, and next time around it would continue from where it left off.
Old December 4th, 2017, 10:03 PM   #7
Bullzi
United States
Bullzi is offline
Try using the unlatch OTU instruction (U)? (RES) will clear out the .POS memory but wont reset the .IN bit.
If you want to post your code you can just make sure to zip it first.
EDIT: ASF is a faster than me
__________________
Old December 4th, 2017, 11:20 PM   #8
anthony.v3a
United States
Ok, that makes sense. I would try the unlatch if I needed it to continue to search. What I'm trying to do is have it find the first available space in the array then MOV a 1 into it. After, RES the CONTROL tag for the next search. The problem I'm coming across is that it will fill the first two available places in the array but will then take 3 or 4 search attempts to fill in the next place. I'm wondering if it has to do with my ONS's. Also, I have it set to INCREMENTAL. Not sure if I should be using the ALL mode. I may attempt to upload the code.
Thanks guys
Old December 5th, 2017, 01:52 AM   #9
anthony.v3a
United States
I attached two pictures of what I have. When I toggle either BMB(1 or 2)_eye I'd like for the FSC to find the first available place in the SPACE[52] array, up to 12 places, with a 0 then MOV a 1 to the space and so on when the next BMB(1 or 2)_eye is toggled.
Old December 5th, 2017, 04:22 AM   #10
daba
United Kingdom
daba is offline
daba's Avatar
Quote:
Looks ok to me.....
Any reason you are using a SINT array ?
Are you assuming it is more "efficient" because you only need to store 0 and 1 values ?
The controller has a 32-bit architecture, so works most efficiently with DINTs. I'll try to set up a test to see how much using SINT arrays knocks the performance.
Talking about efficiency, OTL SPACE[FIND_AVAILABLE_SPACE.POS].0 will be more efficient than the MOV 1, but is less transparent to a casual observer of the code. Properly documented should be OK.
I presume something else is "unloading" the 1's in the array.... Have you thought about what would need to happen if one of the cells was triggered and there ware no spaces available in the array ?
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old December 5th, 2017, 06:10 AM   #11
cwal61
United States
cwal61 is offline
Quote:
This is not a true statement the (RES) instruction resets all bits of the instruction.
Old December 5th, 2017, 07:51 AM   #12
cwal61
United States
cwal61 is offline
If I understand your task then you need something like this. I have included an exported subroutine of the logic. This is uses indirect addressing with an equation to find and write to the correct locations. Good Luck with your project.
Old December 5th, 2017, 08:54 AM   #13
cwal61
United States
cwal61 is offline
If you need to Fill all 52 SINT then you could do this to manage the overflow.
Old December 5th, 2017, 09:19 AM   #14
Doug-P
United States
Doug-P is offline
Doug-P's Avatar
A question from left field. If you're only dealing with '1' and '0' would a bit array not work as well?
__________________
Let's eat Grandma!
Let's eat, Grandma!
Words are very important, but punctuation saves lives...
Old December 5th, 2017, 10:08 AM   #15
Bullzi
United States
Bullzi is offline
Quote:
Yea I should have been more clear and said that the RES will not reset the .in bit by itself, it resets the whole control word.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
