plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 27th, 2017, 11:30 AM   #1
demond1984
United States
demond1984 is offline
demond1984's Avatar
Converting Instruction lists from 90-30 to Rx3i
I'm in the process of upgrading 90-30 to Rx3i, and the 90-30 has instructions lists in the program that are not supported in the Rx3i. Any advice on what would be the best action to convert this into ladder/structured text?
Old November 27th, 2017, 12:36 PM   #2
Steve Bailey
United States
Steve Bailey is offline
Steve Bailey's Avatar
I could be mistaken, but I was under the impression that there is 100% conversion between IL and ladder in the 90-30 and that 90-30 ladder is 100% convertible to Rx3i. Could it be that your 90-30 program is in SFC?
If you can post a backup of your 90-30 project file, I can try to help.
Old November 29th, 2017, 07:51 AM   #3
demond1984
United States
demond1984's Avatar
Thanks Steve.
attached is the backup
Old November 29th, 2017, 05:11 PM   #4
Steve Bailey
United States
The Rx3i does not support IL blocks. The easiest approach is to convert the IL to LD. There was a conversion utility in Versa Pro to convert between LD and IL, but that utility doesn't exist in Machine Edition. I did quick conversion of the SP_AXIS block for you (attached). Be advised that I didn't proofread it or try to download it to a PLC. The other IL block doesn't appear to be called anywhere. At any rate, it is only two lines, so it is a simple enough conversion to LD.
Old December 11th, 2017, 02:41 PM   #5
demond1984
United States
demond1984's Avatar
Steve, sorry it took a while to respond, but I really appreciate the help on this!!!!!! You were a live saver.
Old December 11th, 2017, 07:33 PM   #6
Steve Bailey
United States
You're welcome. Glad I could help.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Question about OSR Rocguy LIVE PLC Questions And Answers 24 March 13th, 2017 06:43 PM
Variable array size call to add-on instruction - A solution Mr Modbus LIVE PLC Questions And Answers 4 July 17th, 2015 08:59 AM
Converting a TI505 to AB. MIRW instruction?? Psymon LIVE PLC Questions And Answers 5 March 26th, 2011 11:37 PM
Status Point Energize (STE) – An Easier Way to Keep Track of Process Status RichardE LIVE PLC Questions And Answers 16 October 29th, 2010 07:52 PM
Same "ONESHOT" in Multiple Locations skyfox LIVE PLC Questions And Answers 21 May 28th, 2007 11:33 AM
