plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 1st, 2017, 10:16 PM   #1
ds7891
United States
ds7891 is offline
24v POE Injector - DIN Rail - Ubiquti
For those of you who use Ubiquiti. You will all know that they use a 24v POE voltage on 50% of their gear instead of the 48v 802.3af standard. Of course, there are pros and cons with this.
Pro being that you can use a passive poe injector for a single piece of Ubiquiti hardware wired directly to your 24v control power.
Con, because passive poe is "old school", finding a DIN mounted inserter that has a decent form factor is almost non existent. According to my Google-fu. That, and any you do find look like they are due back to the 90's.
Anyway...what do you guys use to power your Ubiquiti gear from the 24vdc control voltage that is so common in most control panels these days?
Old December 2nd, 2017, 12:28 AM   #2
Brandon_K
United States
Brandon_K is offline
What are you trying to power downline that is POE? All of the UniFi gear is 802.3af/at at this point. Of course if you're using a Rocket or something for PtP/PtMP that doesn't do you any good. You can always use a 802.3af/at compliant switch in the cabinet and then a INS-8023AF-O at the 24v passive device.
That said, I won't lie. Before they came out with the inline adapters, I have VHB-taped injectors or ToughSwitches to the inside of a cabinet. I always have a Automation Direct FA-REC3 to power plug in devices like that.
Old December 2nd, 2017, 11:09 AM   #3
ds7891
United States
ds7891 is offline
Quote:
Originally Posted by Brandon_K View Post
You can always use a 802.3af/at compliant switch in the cabinet.
A lot of the Ubiquiti stuff we use (Lower grade Rockets, NanoBeam) aren't 802.3af/at compliant. It seems their higher bandwidth/longer range components use the 802.3 voltage.
Most of the Control cabinet we build for the application which we need the 24vdc Ubiquiti gear, utilize a 24vdc UPS, and everything in the cabinet is 24vdc. Other than the main breaker.
If we went to an 802.3af compliant switch, we would need a 48v power supply correct? I never used an industrial 802.3 switch in a control cabinet.
Old December 2nd, 2017, 11:54 AM   #4
ds7891
United States
ds7891 is offline
We have gotten away with powering a few Nanobeams with this:
https://www.amazon.com/gp/product/B0...EH2276JE&psc=1
and
https://www.amazon.com/gp/product/B0...R5ECPZZI&psc=1
It works, no problem.
Looks better than a Toughswitch velcro'd to the side wall of a panel, which we have done as well #Brandon_K, .
Old December 2nd, 2017, 03:54 PM   #5
BryanG
United Kingdom
BryanG is offline
Have just been researching POE injectors and some of those have DC/DC step up converters on board and so can work from a 24V supply. They don't always make it clear in the documentation so it does take some searching. I can't advise on switches but did find single channel injectors.
Old December 2nd, 2017, 05:17 PM   #6
ds7891
United States
ds7891 is offline
Quote:
Which ones did you find, because I looked around and called around to only find 802.3's. Nrton, trendnet, and Moxa's single channel only puts out 48v. And then to hang one of the Ubiquiti adapters off of it is not feasible.
Would love to find a DIN mountable single channel injector that is 24v.
Old December 2nd, 2017, 09:21 PM   #7
jsmith1817
United States
jsmith1817 is offline
I've used these injectors a few times. No issues so far. It's not din rail mount but it beats zip tying it to the back panel.
https://www.data-alliance.net/single...-reset-button/
Old December 3rd, 2017, 06:54 AM   #8
BryanG
United Kingdom
BryanG is offline
Reading back I am still not sure if this is the kind of thing you are looking for, it gives:
IEEE 802.3af PoE,
IEEE 802.3at PoE+
IEEE 802.3 10Base-T,
IEEE 802.3u 100Base-TX,
IEEE 802.3ab 1000Base-T
from a 24V d.c. supply. Haven't used one, I was just looking for 'proof of concept' for a customer who might want to put a camera on to a machine.
https://www.startech.com/Networking-...ctor~POEINJ1GI
Old December 3rd, 2017, 04:41 PM   #9
ds7891
United States
ds7891 is offline
Just found POEtexas.com
Not sure if they have DIN rail adapters.
Will call them tomorrow.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
encoder signal 5V to 24V bennyk@37.com LIVE PLC Questions And Answers 4 February 1st, 2014 07:16 PM
TwinCat examples for how to use TcMC2.lib functions to control motor/linear rail? beoborg LIVE PLC Questions And Answers 0 October 5th, 2012 07:25 AM
