plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 4th, 2017, 08:35 AM   #1
Rob S.
United States
Rob S. is offline
Dog Could you please explain Recipe Extraction using ControlLogix , RS Linx , and Excel ?
Good Morning ,
We had an equipment manufacture in last week. He always giving us a thumbdrive with the machine recipes . They are neatly in catagories with all the recipe settings in this machine. I understand that you go into RS Linx , select DDE / OPC , Topic Configuration , Drill down into your processor , Go into the Topic List and select PLC1 , then select Apply . The laptop I was using did not have Excel on it so I was not able to finish the process.
The real question is , I don't know how this works , and what all these processes are doing. All the recipes are so neatly in tabs , and discriptions
in excel. I imagine that the manufacture created this excel sheet before ,
but I don't see any data or paths in the cells , indicating a Controller Tag
or Program Tag.
Could you guys please explain this process , and technique . I would love to understand this so I can use it all over the plant.
Thanks so much for your help , like always.
Old December 4th, 2017, 08:45 AM   #2
Paully's5.0
United States
Paully's5.0 is offline
I would assume there is some VBA in the background that is handling the actual data exchange and building tags and such. Can you open the VBA editor in Excel? or is it locked?
Old December 4th, 2017, 09:34 AM   #3
Rob S.
United States
Rob S. is offline
I'm sorry. I once knew , but I forgot. Where in Excel do you try to open the VBA Editor ?
Old December 4th, 2017, 10:44 AM   #4
cwal61
United States
cwal61 is offline
Look under View>Toolbars>Visual Basic
Old December 4th, 2017, 10:57 AM   #5
Paully's5.0
United States
You'll have to enable the developer tab, it's not enabled by default.
File -> Options -> Customize Ribbon -> (Right side) check the "Developer" box.
Then go to Developer -> Visual Basic
Old December 4th, 2017, 12:12 PM   #6
Rob S.
United States
Rob S. is offline
Thanks for the information. Yes. there is Visual Basic code . Below is it. I don't really see any code that describes which tag values grab .
Sub GetRecipes_Click()
'Display message box to confirm action.
Dim response As Integer
response = MsgBox(prompt:="Cancel to abort, OK to continue.", Buttons:=vbOKCancel)
'If 'Cancel' is selected, action terminates.
If response = vbCancel Then End
'Opens DDE link and continues routine of 'OK' is selected.
If response = vbOK Then RSIChan = DDEInitiate("RSLinx", "plc1")
'Change cursor to hourglass.
Application.Cursor = xlWait
'Clears Recipe Index on Controls page.
ClearIndex
'Uploads Recipe data from PLC.
GetRcpData
'Writes system date to Controls sheet.
GetDate
'Close dde link.
DDETerminate (RSIChan)
'Change mouse back to pointer.
Application.Cursor = xlDefault
Sheets("Controls").Cells(13, 2).Select
response = MsgBox(prompt:="Upload Complete.")
End Sub
Sub SendRecipes_Click()
response = MsgBox(prompt:="Are you sure? Current PLC values will be overwritten.", Buttons:=vbOKCancel)
If response = vbOK Then RSIChan = RSIChan = DDEInitiate("RSLinx", "PLC1")
'Use Recipe name from Spreadsheet to re-populate Index.
ClearIndex
SendRcpData
'Writes Recipe data to PLC.
Application.DDETerminate (RSIChan)
'Close dde link.
response = MsgBox(prompt:="Download Complete.")
End Sub
Sub SendSingleRecipe_Click()
Dim message, title As String
Dim response1 As Variant
' Set prompt.
message = "Enter a recipe between 0 and 31"
' Set title.
title = "Recipe Entry"
response1 = InputBox(message, title)
End If
If response1 >= 0 And response1 <= 31 Then
Sheets("Controls").Cells(18, 12).Value = response1
Else
If response1 <= 0 Or response1 > 31 Then
Dim response2 As Integer
response2 = MsgBox(prompt:="Invalid Recipe Number Entered. Enter Recipe Number Between 0 and 31.", Buttons:=vbOKCancel)
End If
If response2 = vbOK Or response2 = vbCancel Then End
End If
'ClearIndex
SendSingleRcpData
'Close dde link.
End Sub
Old December 4th, 2017, 01:39 PM   #7
Paully's5.0
United States
I would look deeper into the two subroutines that are referenced:
SendRcpData, SendSingleRcpData
Old December 5th, 2017, 12:51 PM   #8
dcooper33
United States
dcooper33 is offline
dcooper33's Avatar
+1 to Paully's comment.
The subroutines mentioned are probably in a module, rather than in the code you see (probably for worksheet events or button clicks) when you open the VB editor.
Look in the solution explorer under "Modules" and you may find the subroutines that do the actual "DDEPoke" (PLC writes).
__________________
I'll walk a mile in your shoes. Now I'm a mile away, and I got your shoes.
Old December 5th, 2017, 06:29 PM   #9
Rob S.
United States
Rob S. is offline
Thanks Guys . I will look at that tomorrow morning .
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RS Linx To Excel Donnchadh LIVE PLC Questions And Answers 3 January 4th, 2010 02:15 PM
Rockwell Allen Bradley Programming Software, RSLogix 5, RSLogix 500, RS Linx, RSLogix vvcd LIVE PLC Questions And Answers 21 September 24th, 2009 11:04 PM
Which RS Linx would be best to use as a OPC Server Coachman LIVE PLC Questions And Answers 1 June 25th, 2008 02:44 PM
RS Linx Training Guide Myles LIVE PLC Questions And Answers 1 June 2nd, 2008 11:05 AM
"Error" Message In N7 Register On Rs Linx TRACY H LIVE PLC Questions And Answers 2 July 26th, 2004 10:45 PM
