plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 14th, 2017, 01:18 PM   #1
phuz
United States
phuz is offline
Querying all alarms on Wonderware galaxy
I'm not understanding the alarm control manual. I have no problem querying alarms in an area:
\galaxy!Area001
But I'd like to query all alarms in the galaxy. Unfortunately, \galaxy doesn't work. At a minimum, I'd at least like to get all the alarms on the platform and I can't get that working either.
I've tried:
\galaxy!<myPlatform.tagname>
and
\galaxy!<WinPlatform_001.tagname>
and
\galaxy!<me.Platform.tagname>
The only thing I can think of is adding each area individually:
\galaxy!Area001 \galaxy!Area002 \galaxy!Area003
Old December 14th, 2017, 01:23 PM   #2
DBLD99
United States
DBLD99 is offline
If your model view is laid out with a "top" area - ie...
CompanyName
SiteName
Line
etc...
All you have to do is filter your alarms on 'CompanyName' that will give you all the alarms for the entire galaxy. Archestra best practices states that the model view for your areas needs to have a seperate area for every alarm query you want to run. Thats one of the main purposes to have a clean model view with areas contained under each other.
Old December 14th, 2017, 01:31 PM   #3
phuz
United States
phuz is offline
Quote:
CompanyName
SiteName
Line
etc...
With a galaxy named Utility, I have tried \galaxy and \galaxy!Utility with no results. In other words, I set the provider='galaxy' as the only filter and still get nothing.
My formatting must be wrong.
But the manual clearly states you can query an entire platform and this is simply not working:
Code:
\galaxy!<myPlatform.tagname> Shows all alarms from the Winplatform
object hosting the Automation Object.
Old December 14th, 2017, 01:40 PM   #4
DBLD99
United States
DBLD99 is offline
You have to have the AlarmProvider Server name as well
\\ServerAlarmProviderName\Galaxy!Utility
Then all of the Instances need to be contained under the Utility Area in the Model view for the alarms to populate.
Old December 14th, 2017, 01:46 PM   #5
phuz
United States
phuz is offline
That's not true. \\ServerAlarmProviderName\ is only needed for a remote node.
I have no problem with \Galaxy!Area
It queries all the alarms for that area.
I'll admit that I was looking at the deployment tab, rather than the model tab, and I see that now, but that still doesn't help me query the galaxy.
Old December 14th, 2017, 01:55 PM   #6
DBLD99
United States
DBLD99 is offline
I was assuming you had a remotenode - you did not give enough information for me to believe other wise.
If you say you can Query '\Galaxy!Area - Then goes back to my first post that you need a TOP LEVEL AREA - WIth TestArea contained underneath it. This has to be done in the MODEL view. Create a Top Area Called TopArea Drag and drop your undeployed areas 'TestArea' 'TestArea2' etc.. onto the 'TopArea' Area - Deploy
Now query
\Galaxy!TopArea
Old December 14th, 2017, 02:06 PM   #7
phuz
United States
phuz is offline
Now query
\Galaxy!TopArea
Thanks, I'll try that. I've forgotten some of the best practices as it's been 2 1/2 years since I went through the System Platform training and I really haven't had a proper project to do until now.
I appreciate the help and sorry for not specifying it was a local node.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wonderware System Platform 2014 R2: Unable to deploy galaxy node letandat LIVE PLC Questions And Answers 2 November 29th, 2016 09:29 AM
Wonderware Alarm DB Logger stops writing Alarms to Database while Running msohaibbutt LIVE PLC Questions And Answers 2 September 15th, 2016 08:10 AM
Wonderware Distributed Alarms, Historical and Summary SiriusMark LIVE PLC Questions And Answers 2 June 28th, 2014 11:11 AM
.XML or .CSV Alarms in Wonderware BPyles LIVE PLC Questions And Answers 1 April 7th, 2014 06:24 PM
FactoryTalk View Alarms to be converted into Wonderware Alarm fhervrylesestoso LIVE PLC Questions And Answers 0 October 23rd, 2012 06:06 AM
